Wheel Locks
Old Mar 11, 2015 | 12:14 PM
traronf's Avatar
traronf
Default Wheel Locks
New C7 Z51 owner and I want to install the GM wheel locks on my car. My question is do you feel it's ok to remove one wheel lug while the car on on the ground or does the car need to be raised? Any helpful advise would be appreciated.
Old Mar 11, 2015 | 12:43 PM
Glenmcp's Avatar
Glenmcp
You are most likely going to get yes and no answers to this. I have removed and replaced one lug at a time to replace all five lugs without any problems for years. My guess is that the "correct" way is to jack the car.
Old Mar 11, 2015 | 01:01 PM
alienranch's Avatar
alienranch
Agreed. I'm sure you're fine to do it on the ground, but the 'correct' way is undoubtedly to raise it and re-tighten.
Old Mar 11, 2015 | 01:10 PM
dvilin's Avatar
dvilin
No need to raise car if only doing one wheel lug.
Old Mar 11, 2015 | 01:25 PM
Kracka's Avatar
Kracka
I installed one lock per wheel with the car on the ground, then properly torqued all 5 to spec.
Old Mar 11, 2015 | 01:58 PM
Crossed Flags Fan's Avatar
Crossed Flags Fan
Old Mar 11, 2015 | 02:42 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
Old Mar 11, 2015 | 04:37 PM
DucMan 888's Avatar
DucMan 888
St. Jude Donor '15
Default GM Part Number Please?
Would you please provide the GM part number for those? I must be looking in all the wrong places, no findy.
Old Mar 11, 2015 | 07:31 PM
traronf's Avatar
traronf
Thank you all for your responses. I feel better now about doing this. Does anyone know the proper torque for the lug nuts? I have not had a chance to check the manual.
DucMan888 here is the P/N: 19211919
Old Mar 11, 2015 | 07:40 PM
meyerweb's Avatar
meyerweb
You can get the same things for half the price from McGard, via Amazon:
Amazon.com: McGard 24157 Chrome Cone Seat Wheel Locks (M12 x 1.5 Thread Size) - Set of 4: Automotive Amazon.com: McGard 24157 Chrome Cone Seat Wheel Locks (M12 x 1.5 Thread Size) - Set of 4: Automotive
Old Mar 11, 2015 | 07:51 PM
sl33p3r15's Avatar
sl33p3r15
So... Does anyone have a thought on the security offered with the spline style lug nuts?
Some people call them locking lugs, but since the splines are all the same and therefore not really "keyed", they aren't really locking lugs. With that said, I have not heard of anyone using spline style lugs having their wheels stolen.
I ask because I am looking for lug nuts in either black or red, and the spline style are a lot cheaper (3:1) than true locking lugs. call me thrifty.
Old Mar 11, 2015 | 08:06 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
100 lb-ft
The splined lug nuts are probably only slightly better than no locks since professional wheel thieves are likely to carry the spline tool.
If you get the splined nuts, buy a set of 4 Gorilla locks. They look like splined nuts but are keyed with one or more splines out of sequence.
Old Mar 11, 2015 | 08:17 PM
Topsarge12R's Avatar
Topsarge12R
No problem at all if your just changing one lug. I have the GM lock nuts. Bought them at the dealer.
Old Mar 11, 2015 | 08:26 PM
Ghunt's Avatar
Ghunt
In watching the Atlanta 500 last week, nascar rules say that a car can go out on the track with only 3 lug nuts on.
Not me......
Old Mar 11, 2015 | 08:32 PM
vetorama's Avatar
vetorama
Default Link
Used the link and amazon said will not fit 2014 Corvette.
Old Mar 11, 2015 | 08:36 PM
Entaille's Avatar
Entaille
+1. wheels not going to move if you're only taking one off. I am sure you will get some conflicting opinions regardless.
Old Mar 12, 2015 | 12:01 AM
mendeldl's Avatar
mendeldl
My C7 is coming with Black Machined Faced Aluminum wheels. Does anyone know if the lugs are black or are they chrome?
To Wheel Locks
Old Mar 12, 2015 | 12:07 AM
Glen e's Avatar
Glen e
amazon shows that for many aftermarket items....for c7
Old Mar 12, 2015 | 12:16 AM
Rave's Avatar
Rave
Consider it this way. If you remove one lug nut and the wheel moves on the other 4 lugs (at all), the other four lugs weren't tight. My thought is, you shouldn't have any issue removing and replacing one lug.
Old Mar 12, 2015 | 12:37 AM
nmvettec7's Avatar
nmvettec7
100%
