Performance track management system availability
Old Mar 14, 2015 | 12:31 PM
Newman Boy's Avatar
Newman Boy
Default Performance track management system availability
I stopped by a local dealership to test drive a Stingray 7 speed. The car was on the showroom floor and I decided since it started to rain to forego the drive.
However, in discussing the PTMS availability the sales manager said it was available on the base model. I thought it was only available on the Z51 with MRC. He also said the Z51 had a special oil pan but didn't know if it had dry sump.
The Corvette sales person sat mute--good call I imagine.
At any rate, am I correct about the availability of the PTSM/
Old Mar 14, 2015 | 12:33 PM
Zymurgy's Avatar
Zymurgy
Moderator
Yes. PTM is only available with MSRC which is only available on Z51.
Of course, the Z51 has a dry sump oiling system.
Old Mar 14, 2015 | 12:39 PM
Zymurgy's Avatar
Zymurgy
Moderator
From the Online Order/Reference Guide:
B4Z Performance Traction Management
Included and only available with (FE4) Magnetic Selective Ride Control.
B4Z is a Reference Only RPO, meaning it cannot be ordered directly but comes as part of another option.
FE4 Magnetic Selective Ride Control
Includes (B4Z) Performance Traction Management.
FE4 is only available on Z51s.
Old Mar 14, 2015 | 12:41 PM
Woodson's Avatar
Woodson
Wow. At least make sure they understand allocation before you put down a deposit. Better yet, go somewhere else.
Old Mar 14, 2015 | 11:15 PM
EcoBrick Bob's Avatar
EcoBrick Bob
Dazed Confused & Verklemp
If you order from them, make sure they order a Corvette and not a CAMARO!!!!!! LOL
Old Mar 15, 2015 | 01:17 AM
Thunder22's Avatar
Thunder22
Old Mar 15, 2015 | 11:01 AM
Newman Boy's Avatar
Newman Boy
actually sitting in a different dealership waiting for them to pull around a Z51 7speed for me to test drive. I will report back in later.
Old Mar 15, 2015 | 02:14 PM
Newman Boy's Avatar
Newman Boy
I sure have the luck. The salesperson had to move several cars to get to the vehicle. I actually had to maneuver it around vehicles to drive it. Now my luck: could not get the dashboard to illuminate. No one at the dealership could figure it out. Did not know how much gas was in it. Therefore, drove it near the dealership for about five minutes.
The little bit I drove it makes me want one very bad.
Where is the magic button to illuminate the instrument panel?
Thanks,
Jim
Old Mar 15, 2015 | 02:30 PM
Woodson's Avatar
Woodson
Thanks,
Jim
Mine does this. Try pulling and replacing fuse #25 under the hood.
Old Mar 17, 2015 | 07:37 PM
First Z06's Avatar
First Z06
I HAVE to add my $0.02 to this one. I have a '15 Z51 coupe with 7 speed & MRC. Love the car.
My dash will go black if I enter the car in the following manner: With the car locked, 1. Open the rear hatch with the button above the license plate, 2. Walk around and open the driver side door, 3. Walk back and close the hatch, 4. Get in the car and start the engine - The dash will not illuminate as you mentioned above. If I walk away and let the car sit for 5 minutes and enter the car through the driver door without opening the hatch everything usually works just fine!!! (#25 fuse has not blown or the dash would not illuminate. Am I correct?) The dealer has replaced the instrument cluster without remedying the problem.
GM Tech is "Working" on this in Detroit and wants to see the car at the dealership when I take it out of storage in a couple of weeks. I will mention the # 25 fuse to them anyway, but we think mine is a software issue.
Send me an e-mail if you want any further info on my issue with this.
Old Mar 17, 2015 | 07:40 PM
First Z06's Avatar
First Z06
You probably 'reset' the instrument cluster by shutting the car down when you pulled the fuse????
Old Mar 17, 2015 | 08:26 PM
Woodson's Avatar
Woodson
My dash will go black if I enter the car in the following manner: With the car locked, 1. Open the rear hatch with the button above the license plate, 2. Walk around and open the driver side door, 3. Walk back and close the hatch, 4. Get in the car and start the engine - The dash will not illuminate as you mentioned above. If I walk away and let the car sit for 5 minutes and enter the car through the driver door without opening the hatch everything usually works just fine!!! (#25 fuse has not blown or the dash would not illuminate. Am I correct?) .
Completely describes my situation.
Old Mar 17, 2015 | 08:27 PM
Woodson's Avatar
Woodson
Yes.
Old Mar 17, 2015 | 08:40 PM
LrgZ51's Avatar
LrgZ51
You guys know the doctor doctor routine, right?
Seriously, I might have to try that just to see what happens.
Old Mar 17, 2015 | 09:01 PM
First Z06's Avatar
First Z06
The folks at GM wanted me to send a video of my 'problem'. After viewing the video, they were able to duplicate the issue on 2 Corvettes at the Tech Center in Detroit. Now they want me to take it to the dealer and leave it with them - when I take the car out of storage in a couple of weeks so they can 'look' at the car!!! As if they can't fix it on their cars in Detroit and download the fix to the dealer in Columbus. It has to be a software issue.
The car is not going to be left with the dealer for the GM Techs to fiddle with. They have their cars in Detroit to do that with!! Mine will be at the dealer to be FIXED.
Old Mar 18, 2015 | 08:25 AM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
Pardon the on-topic interruption, but FWIW, non-MSRC cars do get Competitive Driving Mode in lieu of PTM.
Old Mar 18, 2015 | 09:34 AM
alienranch's Avatar
alienranch
Excellent procedural rundown! This should keep some folks around here from thinking they're going crazy (or have a possessed car).
Old Mar 18, 2015 | 02:35 PM
boxster99t's Avatar
boxster99t
Holy internal combustion engine, Batman! How did you ever figure out that specific sequence of events?
I'd try it on my convertible but with my luck it may break the flux capacitor.
To Performance track management system availability
