Don't need one with the C7, it resets automatically.
From the Owner's Manual:
TPMS Sensor Matching Process — Auto Learn Function
Each TPMS sensor has a unique identification code. The identification code needs to be matched to a new tire/wheel position after rotating the tires or replacing one or more of the TPMS sensors. When a tire is installed, the vehicle must be stationary for about 20 minutes before the system recalculates. The following relearn process takes up to 10 minutes, driving at a minimum speed of 19 km/h (12 mph). A dash (-) or pressure value will display in the DIC.
Not needed. The C7 TPMS auto calibrate themselves if you move them around/swap wheels.
I rotated my tires side to side. Once done, I lowered the new LF tire to 24psi. I started the car and the monitor read LF 24. The car never moved. I then inflated the tire back to 30 psi. I started the car again and the monitor read LF 30. Again, the car never moved. Automatic!
I have owned three sets of the correct sensors, two sets auto-calibrated, one did not. See the procedure I wrote in the tech section you can do from the drivers seat, with no service tool, to force the calibration if the auto does not work.
same here, put hoosiers on Friday night and when i started car next day the tpms were set.
