Solution to latching hatch
Old May 29, 2015 | 05:10 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Default Solution to latching hatch
I've been commenting about my need to have my door open to allow my hatch latch for 1 1/2 years. I recent post by someone who has been pressing the hatch frame to latch that said his hatch frame cracked reinforced my "keeping the door open" was the right approach for me. However now there is an alternative I just received in the mail, Window Valet. It allows you to remotly open and close the windows with your key FOB! Just hit the open door switch 3 times and the windows open. Then you can easily close the hatch the same as with the door open.
A PDF is not really needed since it is so simple but for those non-DIY folks perhaps it will be a help since it describes the problem, all the things I have tried in 1 1/2 years as well as how easy it is to install and how it works: http://netwelding.com/Latch_Hatch.pdf
Easy Install and Works Great!
Old May 29, 2015 | 08:38 PM
EcoBrick Bob's Avatar
EcoBrick Bob
Dazed Confused & Verklemp
I went to that website and found no where I could get a price or the ability to order. HELP????
How much did it cost? How did you order it?
Old May 29, 2015 | 09:00 PM
JerryU's Avatar
JerryU
They are not a forum advertiser so can't put their website on the forum. However they have a link on their front page to a 2014/2015 Vette. Lots if info on my PDF.
Old May 29, 2015 | 10:37 PM
c8nukeZ51's Avatar
c8nukeZ51
Might be worth every bit of the $150 they're asking
Old May 29, 2015 | 10:47 PM
Glen e's Avatar
Glen e
Except for those of us that do not have the problem. My hatch has shut perfectly with the inner pull down for 7000 miles.
Old May 29, 2015 | 11:04 PM
Elegant1's Avatar
Elegant1
maybe you are the only one with working magic mystery metal vents mine needs the force of an elephant to close.
Old May 29, 2015 | 11:44 PM
rcooper's Avatar
rcooper
St. Jude Donor '15
I am happy for the '16 buyers as their hatch will have the pull down motor. I am really tired of having to use the " that cute Ginger" method, it works but it's a bit of a pain. I am going to check into the Window Valet, seems to be a good idea and worth the $150.
Old May 30, 2015 | 12:04 AM
dbdave's Avatar
dbdave
I'd much rather give GM $150 to install the '16 hatch pulldown than have to fumble around with the fob to allow me to close the hatch.
Old May 30, 2015 | 12:06 AM
-CM-'s Avatar
-CM-
After >11K miles and regular use, my rear hatch is still a pain to close. I'll definitely be getting one of these.
Does it allow for partial lowering of the windows, or do they always go all the way down?
Old May 30, 2015 | 12:35 AM
10mm_'s Avatar
10mm_
St. Jude Donor '15
I just put my hand on the peak of the body line on the hatch and close it firmly, closes fine every time.
Old May 30, 2015 | 12:43 AM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
I wouldn't spend 2 dollars for something that makes it easier to close my hatch, waste of money IMO. If you don't have spindly girly arms you can close it just fine.
Old May 30, 2015 | 12:57 AM
gwalsh88's Avatar
gwalsh88
[QUOTE=themonk;1589733678]I wouldn't spend 2 dollars for something that makes it easier to close my hatch, waste of money IMO. If you don't have spindly girly arms you can close it just fine. [/QUO
Old May 30, 2015 | 02:09 AM
JerryU's Avatar
JerryU
Funny, some folks don't understand that some cars are different. You can pull down my hatch using the GM hand hold with all your "strong arms" and bet it won't close. For what it's worth I've be using a weight machine with dumbbells for warm-up, 7 days a week for over 30 years ! At 72, in addition to using it and a treadmill every day, I do 3 sets of 10 pull-ups as part of my every 1/3 day back routine! Not quite still curling my own weight but close!
Happiness is a tight Vette!
PS: GM didn't revert back to the motorized pull down because folks were weak! Bet the paint cracking on the hatch was one reason. The frame flexes and if it does enough the paint can crack. One poster who has been pushing in the center of the frame to latch had his frame crack not just his paint!
Even all this is no help for some C7's!
Old May 30, 2015 | 08:26 AM
c8nukeZ51's Avatar
c8nukeZ51
Putting the hatch issue aside I've missed to ability to raise and lower windows with the key fob. A lot of my pasted, less expensive cars had it so why not the C7. Awful nice to get into a well vented car that's been sitting in the hot sun.
Old May 30, 2015 | 08:50 AM
RussM05's Avatar
RussM05
I just slam it down. Pushing on the hatch is just asking for trouble.
Old May 30, 2015 | 08:56 AM
JerryU's Avatar
JerryU
In fact that is at least 1/2 the reason I bought the Window Valet! With our hot summers in SC, doesn't take long for the interior to get very hot when sitting in the sun. Frankly I really don't mind keeping my door open to close the hatch! I'll probably still do it much of the time. However in the summer it will be nice to use when I have groceries to put in the back! I'll use the FOB to open the windows, close the hatch then drive until it's cool enough to raise the windows with the door switches.
Old May 30, 2015 | 09:01 AM
Larry/car's Avatar
Larry/car
Purchase a convertible. No issues with trunk lid closing.
To Solution to latching hatch
Old May 30, 2015 | 10:08 AM
MJZ's Avatar
MJZ
St. Jude Donor '15
Just ordered, thanks for the info. I wanted it just for the ability to open the windows while still in my office on hot days.
Old May 30, 2015 | 10:39 AM
cheapthrills's Avatar
cheapthrills
Even my old truck has this and I love it.
Old May 30, 2015 | 10:57 AM
scott53's Avatar
scott53
Same here Glen. Mine closes fine using the handle on the right underside of the hatch.
