Lost objects under seats
Old May 31, 2015 | 03:43 PM
Boiler2's Avatar
Boiler2
Default Lost objects under seats
Small objects that fallen under the seats are lost to the ages unless you remove the seat. Very tight place. Almost impossible to retrieve by hand unless you are lucky. A small money clip slipped from my hands and went into this "well". It was a wedding present from my wife many, many years ago. I had to reclaim it from the dead zone. Could not even see it...no less try to grab is. Finally resorted to removing the seat. This might be a cmmon occurrence for others......SO...fair warning.
You will need a 15 mm deep socket, a ratchet and 8+ inch extension to remove the 4 hold down nuts. Removal of the plastic covers over the front bolts is not difficult. From the rear side of the cover pull up and forward and the one attachment clip releases easily. Remove the 4 nuts and you are ready to lift the seat up. Seat is heavier than expected; and the most difficult part of the task is aligning the seat back onto the bolts for re-assembly. I was able to manage it myself, but an extra set of hands would make it an easier job. Total turn around time is less than 15 minutes. As for me.....no more small objects in my pockets while in this car.
Old May 31, 2015 | 03:49 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
No issues with the electrical connections?
Old May 31, 2015 | 04:09 PM
meyerweb's Avatar
meyerweb
Try rubber banding a piece of window screen over the end of a vacuum cleaner hose and sliding it under there. If what you seek isn't too heavy, you might be able to retrieve it that way.
Old May 31, 2015 | 04:34 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Good idea. But I'd just let my large canister vac suck it up then get it from the canister.
Made a suggestion to the last fellow who lost his girlfriends ring under the seat but he went to the Chevy dealer instead. The Vette brakes are so good you can easily hit over one "g" on a quick stop. That's like tilting the car 45 degrees from the horizontal. There is a chance it will shoot to the front. Easy to try. Now if you find a 20 degree hill and really slam on the brakes going downhill sure you get the equivalent of a 60 degree tilt from the horizontal!
Old May 31, 2015 | 04:38 PM
Boiler2's Avatar
Boiler2
Did not touch the electricals. No need. Sufficient slack in wire harness to lift the seat up 3-5 inches and get a clear view and access. As I said, 2 sets of hands would have made the job easier. No need to remove the seat from the vehicle.
Old May 31, 2015 | 04:44 PM
Boiler2's Avatar
Boiler2
I'm laughing as I read you post. I put the car through the g force maneuvers to no avail. May have made matters worse. The clip was wedged behind the front inboard hold down bolt assembly and the cut out of the carpet. It was there for good...even a vacuum would not have helped. Tight space for most vacuum hoses.
Old May 31, 2015 | 05:16 PM
JerryU's Avatar
JerryU
Thanks, think I'll just let that quarter stay there! Good instructions on how to get the seat off!
Just traded my wife's Cayenne because to replace the battery it looks like a 3 hour job (according to a YouTube video) and they have a special wrench to remove the front driver's seat. Lots of wires! Bought the special socket needed but was going on a 1000 mile trip, the battery was only reading 11.9 volts and the car was 5 years old and due to be replaced! Was going to buy an emergency starter battery and said to the wife, since we we're in town, lets get the car washed and see what the new Mercedes/BMW SUV looks like and what we can get for our car. When we went to the car wash the fellow who takes the money said "Nice car but it will cost $700 to change the battery!" I said how do you know and he replied someone was just in complaining! The closest Porsche dealer is 75 minutes away! His comment was a "sign!" Walked out of the dealer with a BMW SUV the same day, great car. They are in town and I don't have to pay $250 for an oil change since no one but Porsche can reset the oil change indicator!!
Old May 31, 2015 | 05:17 PM
stevebz06's Avatar
stevebz06
That the seats are heavier than expected is an understatement. I had to pull a seat out of a Lincoln Town Car and discovered the weight is about the same.
Old May 31, 2015 | 05:27 PM
meyerweb's Avatar
meyerweb
That would work, too, as long as the shop vac isn't so full of, umm, "stuff" that you'll never find what you're looking for.
Electric motors are heavy, and our seats have quite a few, especially if you have the ventilated versions with multiple fans.
Old May 31, 2015 | 06:45 PM
Boiler2's Avatar
Boiler2
Surely let the quarters stay there. But know that it's easy to retrieve that wedding ring should the need arise. If fact, it is much easier than I expected and better than the vacuum or g options which may not even work.
Old Jun 1, 2015 | 11:12 PM
Cobra64's Avatar
Cobra64
Try a magnet.
Old Jun 1, 2015 | 11:30 PM
fpcopo's Avatar
fpcopo
Originally Posted by Cobra64
Try a magnet.
Can't you just raise the seat to it's full height to get your hands under there?
Old Jun 2, 2015 | 12:38 AM
Glad you retrieved the money clip.
Old Jun 2, 2015 | 07:02 AM
WelderGuy's Avatar
WelderGuy
I've been stuffing towels between the seats and the console of my cars for several years. I haven't lost anything since I started doing that.
Having a black interior helps with color selection, but chances are you can find a towel in a color that's not too objectionable.
Old Jun 2, 2015 | 07:07 AM
C7Joy's Avatar
C7Joy
Sounds like a real forbidden zone under that seat.
Old Jun 2, 2015 | 08:06 AM
JerryU's Avatar
JerryU
It is! I use a stylus with my cell phone and it's clipped to my case. I've had it come unclipped several times and fall into the track area. Had a hard time retrieving. Not worrying about it as much as being sure it does not get wedged in the seat track when it goes in the exit position. Now I don't turn on my phone when driving (for a couple of reasons) and I never take it out! Nothing is that important!
Old Jun 2, 2015 | 11:30 AM
Boiler2's Avatar
Boiler2
Try a magnet.
Only iron and nickel are magnetic....silver (my case), gold, etc. are not magnetic. Not like retrieving a lost nut.
Old Jun 2, 2015 | 11:35 AM
Boiler2's Avatar
Boiler2
I hate to put it this way, but you must think I'm stupid. Of course that was my first attempt....and to no avail. It has worked on all other cars that I have owned but not this one. This is a very tight space....at least for my hands which are not small.
Old Jun 2, 2015 | 09:00 PM
stevebz06's Avatar
stevebz06
You are right. But I have several cars with manual seats and I don't find that it is a major hardship to manually adjust them and I don't have to worry about other failures that are cropping up on memory seats.
What I am seeing on this forum is evidence that we have reached the point of diminishing returns where the push to make the car more luxurious is actually making the car less useable because its spending more and more time at a service center and Heaven help the people who try to keep it going past the warranty period. Not to mention that all these motors and relays, etc take up space and add weight which uses more fuel and slows the car down.
This is being directed to any GM types who might be reading and I hope are starting to wonder about this direction of design evolution where complexity for the sake of complexity seems to be the norm.
To Lost objects under seats
