2016 EYT -- chrome bar delete
Old Jul 9, 2015 | 07:39 PM
  #41
kevincol's Avatar
kevincol
Originally Posted by STStingray
Maybe they'll just add a piece of tape, vinyl, etc., over the chrome piece like so many have done already, which might explain what the OP saw. This would be no different than adding vinyl stripes, or other stick-on items, at some point while on the assembly line, or shortly thereafter... or later as a dealer installed item... or not.
I will let you know once I get the car!
Old Jul 9, 2015 | 07:42 PM
  #42
kevincol's Avatar
kevincol
Originally Posted by Boiler_81
Thanks for the follow up, it looks like it will be taken care of at Bowling Green. I wasn't looking forward to having to have mine repaired at the dealer.
It sounds as if it was a broadcast issue or a supplier issue. Either way, I'm happy it is being taken care of.
Are you driving your car home from the Museum delivery?
yes, with my 9yr. old! He birthed the car on the line and asks me every day when we are going back out there to drive it home... I can't wait to get my OnStar finally active so I can also track where in the parking lot it is and when it was last started...
Old Jul 9, 2015 | 09:43 PM
  #43
Boiler_81's Avatar
Boiler_81
I don't think so. Normal practice is to have the part come in from the supplier in the final configuration. I'm sticking to a supplier or broadcast issue.
Normal practice is to reschedule if at all possible if it is a supply issue. If for some reason they can not, the assembly plant will build the cars and then rework when parts become available. Since the front bumpers come down the line and meet the correct car, they would have had to store the bumper off line without damaging it. Since this is nearly impossible in the factory environment, they go ahead and install it to the car knowing it will have to come off later to rework.
In another thread, I posted an experience I had with an electronic module with incorrect programming (another OEM, not GM). In that case we could not have corrected parts for a week. The plant keep running and storing cars. When we finally got parts they went to the assembly line. When we got ahead of the assembly line, parts became available for rework. To perform the rework, a few other parts had to be removed to get to the module. Changing process for a missing part is almost impossible.
Old Jul 9, 2015 | 09:47 PM
  #44
Boiler_81's Avatar
Boiler_81
Very cool! There is a lot of pretty country between Bowling Green and Bellevue WA.
Old Jul 9, 2015 | 10:14 PM
  #45
Carmonaa1's Avatar
Carmonaa1
Cruising
I'm surprised no one posted this yet from the 2016 marketing materials....EYT definitely deletes chrome strip. They wouldn't have taken the option to this level if it wasn't intended to be followed up on
Old Jul 9, 2015 | 10:23 PM
  #46
CaptV1VR's Avatar
CaptV1VR
My thoughts exactly!!!! Where can you get real black lug nuts that are not painted?
I bought mine several months ago from (Gorilla Nuts)
Also a Carbon flash strip for the grill
Old Jul 9, 2015 | 11:18 PM
  #47
docprego's Avatar
docprego
There's no question it was supposed to be included. The only question now is; will it be included?
Old Jul 10, 2015 | 06:28 AM
  #48
jschindler's Avatar
jschindler
It still absolutely amazes me that Amazon gives better customer service on a $20 purchase than the auto makers are willing to give on a $70,000 vehicle.
Old Jul 10, 2015 | 12:31 PM
  #49
kevincol's Avatar
kevincol
What model in particular did you purchase?
Old Jul 10, 2015 | 12:50 PM
  #50
Pisswilly's Avatar
Pisswilly
The whole stock grill should be re-designed, the chrome bar and vertical bars look like braces.
Old Jul 10, 2015 | 03:27 PM
  #51
daleong's Avatar
daleong
The first guy on the forum just had his 2016 delivered to his dealer with a VIN 40 cars in front of mine, while mine is still at the factory. Notably its a chrome badge car...
Just one data point that a rework may be going on.
Old Jul 10, 2015 | 03:34 PM
  #52
kevincol's Avatar
kevincol
Mine is still at the factory according to OnStar...
Old Jul 10, 2015 | 03:43 PM
  #53
docprego's Avatar
docprego
As was mine this morning. I'm going to check again in about an hour.
I really think EYT is the reason.
Old Jul 10, 2015 | 03:47 PM
  #54
daleong's Avatar
daleong
Me too. It will be great relief when we find the first person who has EYT and gets loaded on a truck or moved..
Kevin - does NCM have any invoice or ETA on when they will get yours?
Old Jul 10, 2015 | 04:29 PM
  #55
vetteazul's Avatar
vetteazul
6th Gear
I think I'm in the same boat. My VIN is very low as you know, and I also have the EYT option and mine is still showing 4B00 - Bayed.
Old Jul 10, 2015 | 04:30 PM
  #56
docprego's Avatar
docprego
Are you OnStar GPS tracking?
Old Jul 10, 2015 | 04:58 PM
  #57
kevincol's Avatar
kevincol
Mine is also still showing 4B00....
To 2016 EYT -- chrome bar delete
Old Jul 10, 2015 | 05:01 PM
  #58
40flier's Avatar
40flier
As posted....VIN 12 and bayed and EYT
Old Jul 10, 2015 | 05:02 PM
  #59
kevincol's Avatar
kevincol
Originally Posted by 40flier
As posted....VIN 12 and bayed.
I am assuming based on the thread title that you have EYT? I'm VIN 776 so please let us know when you see movement if you do have EYT.
Old Jul 10, 2015 | 05:04 PM
  #60
40flier's Avatar
40flier
McMul predicted delivery in the next two weeks, but we didn't discuss the grill bar.
