What is the row of lights across the top of the Track mode display?
Old 08-04-2015, 10:50 AM
TEXHAWK0
TEXHAWK0's Avatar
Default What is the row of lights across the top of the Track mode display?
I have seen a couple of lights on both ends of the row, flash green, but have not observed other color changes.
Do the lights change to indicate approaching red line, or are they for some other purpose?
Have searched owner's manual, but can find no reference.
Oops! Just found it... they are shift lights... but they are so close to the top of the display, I never noticed them..
Old 08-04-2015, 10:58 AM
nmvettec7
nmvettec7's Avatar
Does the track mode on the 1LT, the 2LT and the 3LT all work the same and show the same data and graphs?
Does it make a difference between a M7 or A8?
Old 08-04-2015, 11:33 AM
alienranch
Support Corvetteforum!
alienranch's Avatar
I don't believe it is dependent on transmission type or trim level. Standard across the board.
Old 08-04-2015, 11:38 AM
aj98
aj98's Avatar
The shift lights also appear in the hud if you have the sweeping tach w/ linear g-meter display selected
To What is the row of lights across the top of the Track mode display?
Quick Reply: What is the row of lights across the top of the Track mode display?
