Visor Warnings
Old Aug 11, 2015 | 07:11 PM
flynhi's Avatar
flynhi
Default Visor Warnings
Already tired of seeing these warning notices on the sun visors. Any way to remove these without destroying the underlying material?
Old Aug 11, 2015 | 07:18 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Try the search, there have been a lot of threads about how to do this, some successful, some not so much. Good luck!
Old Aug 11, 2015 | 08:10 PM
sanantguy's Avatar
sanantguy
or i can just tell dude.
heat gun and goo gone.
Old Aug 11, 2015 | 08:16 PM
CaryBob's Avatar
CaryBob
Not everyone has been successful in removing the stickers from suede, it's apparently easier if you don't have a 3LZ. I had no problem removing them from regular plastic visors, but not so much with the sueded material. The other option is to cover them with a black or carbon-fiber vinyl, which are sold by many vendors.
Old Aug 11, 2015 | 08:34 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
Cover them up rather than remove them.
Old Aug 11, 2015 | 08:44 PM
USMCVETC7's Avatar
USMCVETC7
I removed mine from suede, 2015 3LT, and you can't tell they were ever there. The second one I did was easier then the first and I think that it was because I took more time with it. Used a hair drier on hot instead of a heat gun and left the heat on the sticker for a much longer time to insure the glue was broken down more. Peeled right off, then used a damp microfiber towel with a little "Krud Kutter" on it and the remaining residue came right off. Make sure you have the damp microfiber towel ready to go when you peel the sticker off. The residue comes off faster if it is still warm. Good luck.
Old Aug 11, 2015 | 09:29 PM
Mike02z's Avatar
Mike02z
Since it seemed to be a crap-shoot on whether I could get them off cleanly, I just covered them with CF vinyl stickers.
Eventually I'll purchase a used set of suede visors and try and get the stickers off cleanly. If it works, I'll just swap out my current visors.
Old Aug 11, 2015 | 09:43 PM
owc6's Avatar
owc6
Following all the threads on this issue, it seems to be more an issue of '14s don't have much issue, and the newer the car, the harder it appears to be to remove the label.
Whether this is an issue of a new type of glue being used, or same glue, but it just gets easier with age is anyone's guess.
And I would recommend using a hair dryer rather than a heat gun.
Old Aug 11, 2015 | 10:59 PM
Thepiazza's Avatar
Thepiazza
Removed mine from my non suede visor back when I purchased my car with no issues!
Old Aug 11, 2015 | 11:03 PM
E.T.D. Corvettes's Avatar
E.T.D. Corvettes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
Here: https://www.corvetteforum.com/forums...ce-needed.html
Old Aug 12, 2015 | 12:12 AM
Probably the safest way.
Old Aug 12, 2015 | 10:33 AM
sanantguy's Avatar
sanantguy
if your just going to cover them up. why not try to take them off first, and if that is unacceptable THEN cover them
HMMMMM
Old Aug 12, 2015 | 10:35 AM
sanantguy's Avatar
sanantguy
Funny, mine was about 10 days old when I removed mine in about 15 seconds each with a heat gun.
Why do folks have to make this harder than it is?
Old Aug 12, 2015 | 11:13 AM
Flame Red's Avatar
Flame Red
+1 for a heat gun. 5 minutes and they are gone. If anything is left over, just wipe it with a microfiber towel with some 3M Adhesive Remover sprayed on the towel (not the visor). Like it was never there. Why make it harder than it is and why spend $?
To Visor Warnings
