Another A8 shift question
Old Sep 1, 2015 | 01:36 PM
davanz's Avatar
davanz
Default Another A8 shift question
From what I am reading this must be a common trait. When my 2016 A8 makes its first 1-2 shift from a cold start the shift is delayed, with high rpm, and then a very hard hit into 2nd. After that it is normal. Some have mentioned a dealer visit fix and others have said it has cleared up on its own after so many miles. Please relate your experience if it fixed itself. How many miles, did it gradually get better or self correct quickly, did it stay fixed or default back, etc.?
Old Sep 1, 2015 | 01:38 PM
SharkGrayStingray's Avatar
SharkGrayStingray
mine does it. I just wait an extra few seconds for the engine to warm up, or just manual shift for the first few miles...
I'll go for the software update if/when it gets worse.
Old Sep 1, 2015 | 01:41 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
My car exhibited this trait the first 2-3 times I drove it but it has not recurred. I took a long road trip of about 800 miles and car now has 1200 miles.
Old Sep 1, 2015 | 01:47 PM
BIC's Avatar
BIC
I have 4,000 miles. I can't remember for sure, it was March and a bit cool, but it happened early on a few times. I don't recall it happening in the last few months.
I do note that putting it in Drive when cold, better to wait about 30 seconds for the RPMs to drop to 1000, otherwise get a hard shift into Drive.
Old Sep 1, 2015 | 03:35 PM
newskatercat's Avatar
newskatercat
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Haven't had a problem yet! Shifts crazy fast!
Old Sep 1, 2015 | 05:48 PM
jcp911s's Avatar
jcp911s
I have noticed it just a tiny little bit... I just drive the car with gentle throttle for a few minutes until it warms up... so far the A8 has impressed me with its responsiveness and smoothness... a total non-issue IMHO.
Old Sep 1, 2015 | 06:28 PM
Flame Red's Avatar
Flame Red
Yes, 1-2 shift is delayed until the engine warms up a bit. Seems to go away after a mile or two. Very consistent. Seems to be the nature of the beast for mine.
Old Sep 1, 2015 | 08:01 PM
roadsterboy's Avatar
roadsterboy
Its just cold. That happened in my new Mercedes roadster once and I freaked until the dealer says it just need to reach optimum temp.
Old Sep 1, 2015 | 08:59 PM
HAD2HAV2's Avatar
HAD2HAV2
There was a TSB on this for the 2015 model. Dealer fixed mine. No more hard 1-2 shifts which usually occurred in slow moving traffic. Almost like someone hit me from behind.
Old Sep 1, 2015 | 10:24 PM
iclick's Avatar
iclick
Mine with a 12/18/14 build date never had the 1-2 hard-shift problem, but flared a bit from 1-2 for the first shift when cold for the first month or two. Since then that shift is still a bit soft but not bad enough to take it to the dealer for a software update. No other A8 issues in the past two months, so I assume it's finishing up its adaptive learning process.
Old Sep 1, 2015 | 11:23 PM
fpcopo's Avatar
fpcopo
Mine was built 8/14 and now has 370 miles. It does not exhibit this characteristic. But what I just discovered is when manually downshifting to third, second and first, it rev matches. Very cool!
Old Sep 2, 2015 | 01:55 PM
iclick's Avatar
iclick
Didn't know it would do that. Will try it out at next opportunity.
Old Sep 2, 2015 | 02:38 PM
duanepillar's Avatar
duanepillar
My 2015 does it sometimes as well, The dealer said all of the TSB's are done for my car. If I just give it a few second when backing out it seems to be fine.
Old Sep 2, 2015 | 02:52 PM
Casey VP26's Avatar
Casey VP26
My A8 is 1week old about 200 miles and I do notice erratic shifting until trans warms up.
To Another A8 shift question
