I've done a few runs with the launch control in sport 1 and track PTM modes and the best 0-60 (according to DIC) I have gotten so far is 4.9. What kinds of times are you guys getting on the street? I wouldn't expect the 3.8 magazine time off-track but would hope for low 4's on pavement.
Interesting though, one run I had the PDR timer on also and the PDR 0-60 was .3 seconds faster than the DIC. What gives? Which is correct? Not sure how accurate the DIC is, has anybody compared it to a drag strip timer?
His post was one of the reasons I went back to try to figure out where it was on my '16... The '16's are relegated to using the PDR to get this and if you don't have a PDR, you are out of luck. Unless we get enough folks to complain to GM to add it back to the DIC.
Doesn't sound like he was using launch control. I figured launch control would be pretty good but I do seem to be getting a ton of wheelspin.
I sure hope the PDR timer is accurate. Here's a really nice launch on the side of a road in a heat socked 2015 C7 auto. I was very happy with a 3.6 on hot day and I'm hoping to make some passes at Royal Purple during the winter months when the DA is in the negatives. What I was doing was experimenting with launch control. The 'book' says to stand on the brake in a panic brake mode and floor the accelerator, which is everything against any drag racing I've ever done at the strip in other automatics.
I sure hope the PDR timer is accurate. Here's a really nice launch on the side of a road in a heat socked 2015 C7 auto. I was very happy with a 3.6 on hot summer day and I'm hoping to make some passes at Royal Purple during the winter months when the DA is in the negatives. What I was doing was experimenting with launch control. The 'book' says to stand on the brake in a panic brake mode and floor the accelerator, which is everything against any drag racing I've ever done at the strip in other automatics.
Is that the 2016 with EYT or an earlier EYT and you did the chrome delete?
One thing I noticed with the DIC timer is it will start with any minor movement, where as the PDR timer appears to give you a little rollout somewhat like staging on the drag strip.
