iPhone in cubby
Old Sep 12, 2015 | 06:13 PM
AFVETTE's Avatar
AFVETTE
Default iPhone in cubby
Taking my first cross country in my Stingray and am seeking suggestions on ways to mount my iPhone inside the cubby so I can use its Nav.
Not looking for anything expensive or complicated, but I figured someone here has worked something out.
Thanks in advance and cheers.
Old Sep 13, 2015 | 07:54 AM
Bradysdad's Avatar
Bradysdad
I have a 16 with Apple Play and just found a 4" lightning cable, plugged it into the USB in the cubby, placed the phone in the cubby and closed it up. Apple Play works pretty well to my surprise. If you have a 14 or 15, I am a big fan of ProClip mounting systems.
You can always just set the iPhone sideways in front of the shifter. If plugged into power, the screen should remain on. The problem with mounting in the cubby is you will have to keep the screen down and will not have access to the radio, etc... without always raising/lowering the screen.
Old Sep 13, 2015 | 07:59 AM
Stentplacer's Avatar
Stentplacer
Why would you need phone nav when car has nav built in ?
Old Sep 13, 2015 | 08:06 AM
Bradysdad's Avatar
Bradysdad
Won't have factory nav unless it is a 3LT or he purchased the Nav/PDR option, which I am assuming he did not.
Old Sep 13, 2015 | 08:32 AM
Larry/car's Avatar
Larry/car
It will be interesting to see future Apple Play reviews and how evolution will enhance features.
Old Sep 13, 2015 | 09:11 AM
Mac-427's Avatar
Mac-427
My car is a 2016 2LT without factory Nav. I have an I-phone 6 with the Garmin Nav system installed. Yes, the Imap program works with Carplay, but I usually use Bluetooth instead. I also have a Pro-Clip installed to cradle the phone. Because the Pro-Clip positions my phone perfectly, I don't need a map on the factory monitor. Because of the cumbersome interaction between Carplay and Bluetooth, I find it much more convenient to leave everything on Bluetooth and skip the Carplay The I-phone screen is large enough with the Garmin App that nothing else is needed. I have full use of the monitor without the need to change out of the Carplay map to access Aps like Pandora. To me, this is the best of both worlds, and a permanent solution, even though it requires an outlay of some coin.
Old Sep 13, 2015 | 09:35 AM
AFVETTE's Avatar
AFVETTE
After some time on GOOGLE I'm going with this
Cheers
Old Sep 13, 2015 | 12:22 PM
VETJAZZ's Avatar
VETJAZZ
http://youtu.be/YZBejXHBZM4
Cheers
Good choice!
Old Sep 13, 2015 | 02:09 PM
aj98's Avatar
aj98
not sure you'll get signal if its in the cubby. I put mine in the rear cupholder.
Old Sep 13, 2015 | 05:28 PM
Karlba's Avatar
Karlba
I get signal with my 5s just fine with it in the cubby and the vubby closed. since us want to use the pone for nav and you want cheap, I would take a 2x4 end and cut it off angled wrap velcro around it and stick a small piece of it on the back the phones case, after the trip throw it on a shelf for next time or throw it away, u ask for cheap
Old Sep 13, 2015 | 05:35 PM
AFVETTE's Avatar
AFVETTE
Originally Posted by VETJAZZ
Good choice!
What charger are you using?
Old Sep 14, 2015 | 12:06 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
I think there were some in the for sale section, you might be able to save a little bit. Kenu makes a nifty holder too, its less expensive than the ProClip, but a different style of holder though.
Old Sep 14, 2015 | 12:15 AM
VETJAZZ's Avatar
VETJAZZ
I have a USB plug in the power port and a 5" charging cord.
To iPhone in cubby
