Start-up noise thread answered!
I posted this thread earlier and I thought some who responded would like to know the mystery is solved. I talked with Service Advisor at local Chevy dealer that sells a lot of Corvettes about the fluid/circulating noise I hear for a few moments at cold start up. He said the evaporator core pressurizes at start up and circulates freon through lines located behind the dash. The sound of circulating fluid can be audible initially while system pressurizes. System pressurizes automatically at start up as part of normal functioning independent of driver settings. Thanks!
Gurgle, knock, clicking?
Received 19,456 Likes
'20-'21-'22-'23-'24
Thanks for the update.
I hear no such sound.
Received 1,694 Likes
St. Jude Donor '15
Nice follow through, thanks.
" He said the evaporator core pressurizes at start up..."
That's incorrect. The pressure in the evaporator actually drops because it's on the "low" side of the system.
The only noises I've heard from an auto AC system are the click of the clutch and the slight hissing as the pressure in the system equalizes when I turn the engine off on a hot day.
I don't think the noise you're hearing has anything to do with the AC. If it did, you'd hear the same sounds on every start, not just a cold start.
Received 2,486 Likes
St. Jude Donor '15
"In honor of jpee"
Agree w. above mksz. The sound you may be hearing is more toward coolant circulating through heater core, but if that's the case something else is going on because imo, you shouldn't be hearing that at all. Which is what the second poster in your other thread, Bob Guzzy said, too. And I would also say, yes, with a/c and fan off, there are fluids circulating but it should be almost inaudible.
From a GM Bulletin
The Z51 Performance Package has a high performance dry sump lubrication system. This system operates differently than a standard engine lubrication system. Check the oil level only after the engine has been thoroughly warmed up and then check after a minimum of 5 minutes but no more than 15 minutes of engine shutoff. This ensures that the oil level reading obtained will be accurate.
Some customers may comment on a noise similar to running water that can be heard from the dry sump oil tank area when the engine is cold and started. This is a normal sound caused by the oil returning to the tank.
You would almost swear is was water rushing in the glove box or upper air bag area.
St. Jude Donor '15
"In honor of jpee"
From a GM Bulletin
