On my 15 I noticed in reverse 1/3 ofbthe image on the bottom of the screen is the image of my license plate, is this normal or is an adjustment of the camera needed?
It's a 'FISHEYE LENS' that shows about 160 to 180 degrees of coverage. I don't think there is any adjustment the can be made to it, and it you did manage to adjust it, the 1/3rd of the camera would be showing the sky!
I found if you really crank down on the license plate bolts at the top, the made the bottom of the license plate stick out more. Might try loosening them up a little bit so the bottom of the plate sits a little more flush if it doesn't already.
