Infotainment screen flickering... AGAIN!
Old Sep 27, 2015 | 10:28 PM
BigJoe's Avatar
BigJoe
Default Infotainment screen flickering... AGAIN!
Screen was replaced (or at least that is what the dealer said) about a year ago and it has been perfect until last night. Got home and pulling into the garage the screen went black. Turned the car off and restarted and the screen came back on then started flickering then went black again within seconds.
I thought fixing something like that would fix it for good. Sigh, looks like its back to the dealer.
Old Sep 27, 2015 | 10:33 PM
Joy c7's Avatar
Joy c7
Well that sucks! Hope you get it fixed.
Old Sep 27, 2015 | 10:36 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
tell them to check the connection, that's what was wrong with mine.
Old Sep 27, 2015 | 10:38 PM
VETJAZZ's Avatar
VETJAZZ
Not good news. I had mine replaced last month and thought that was it. Please keep us updated.
Old Sep 27, 2015 | 11:01 PM
not08crmanymore's Avatar
not08crmanymore
Mine's doing it too. I recorded it with my phone to show the dealer.They haven't done anything about it yet but we'll see.
Old Sep 28, 2015 | 09:09 AM
PUGPROUD's Avatar
PUGPROUD
Mine is going in on 10/7 for same problem.
Old Sep 28, 2015 | 03:37 PM
BigJoe's Avatar
BigJoe
This morning it screen was back to normal and didn't flicker a bit in the way to work. Only odd thing is the radio was on the Sirius default preview station even though the radio was tuned to some FM station. When I changed the station and went back to the same FM station the Sirius feed was gone.
Crossing my fingers that the black outs were a one-time anomaly.
Old Sep 28, 2015 | 03:50 PM
not08crmanymore
If any of you guys find out what the issue is thru your dealer please post up!
Old Sep 28, 2015 | 05:16 PM
Stein's Avatar
Stein
From: Yopper of 52'yrs presently reside in WI Wisconsin
Had mine replaced about two weeks ago on 2014. So far all good. 14K miles on the car
Old Sep 28, 2015 | 11:19 PM
Jbal's Avatar
Jbal
Mine flickers on occasion-open the door, then close & all is well.
Old Sep 28, 2015 | 11:31 PM
not08crmanymore
Did they tell you the issue that was causing it to flicker?
Old Sep 28, 2015 | 11:33 PM
Hopefully it is just something like a loose connection. Would suck if it required a screen replacement again.
Old Oct 4, 2015 | 02:45 PM
Spinny's Avatar
Spinny
My '15 with 6K on the clock started to do it about a week ago. Opening and closing the screen seems to cure the problem for a while. Does anybody know what really causes the problem?
Old Oct 4, 2015 | 04:40 PM
Vetteram's Avatar
Vetteram
My screen went blank a couple of months ago, if I touched the blank screen in the right place the station would change, Bluetooth would not work. Dealer replaced the screen, all was good till a couple of days ago, started the car and screen was blank. Went straight to the dealer and they worked on it for three hours. Seems the problem was a bad connection at the HMI module. According to the invoice grease was applied to all connectors and all is good. The screen seems brighter to me now, time will tell if this is the fix.
Old Jan 12, 2016 | 07:32 PM
Prodago's Avatar
Prodago
All good things right! Screen lasted what, several months! Doing same thing. They reprogrammed, re-flashed and replaced screen. I'm thinking that this will never be repaired for good, so I want to fix it myself.I've already replaced dash so that part is no biggie. Here's my question and main reason for post. Does anyone know how much a screen and the wire cost and where I can get it other than dealer? Do they make an aftermarket one perhaps? thank you
I'm at 31314 miles so warranty running out
Old Jan 25, 2016 | 06:41 PM
JLargo's Avatar
JLargo
Joy, mine went out tonight for about 30 seconds and then came back on. Mine is a 2016 built in November, so I guess they haven't fixed anything.
Old Jan 26, 2016 | 01:29 PM
Prodago's Avatar
Prodago
dealer cost for screen $700
To Infotainment screen flickering... AGAIN!
Old Apr 7, 2018 | 12:04 AM
adriankapl's Avatar
adriankapl
anyone find out what is wrong? could it be low voltage on battery?
Old Apr 7, 2018 | 01:19 AM
Flame Red's Avatar
Flame Red
If you have a warranty still, why pay yourself?
There was a thread on this forum where the poster listed the company and contact information for the people that refurbish the screens. Much cheaper than GM new. I believe the ribbon cable is the issue and they can fix that. But it is same exact GM screen.
I thought I saved the post but am sorry but I could not find it.
Old Apr 7, 2018 | 02:22 AM
BigJoe's Avatar
BigJoe
My old thread back from the dead... I never followed up on my problem. The dealer wound up replacing what he called the center stack under warranty back in 2015. What that includes I don't know. Been fine since then. Only difference is before I hid my garage door opener behind the screen so I opened and closed the screen at least twice a day. After the replacement I put the opener in a different place so I rarely open the screen. Maybe not opening the screen so often helps?
