Order Change
Old Sep 29, 2015 | 02:41 AM
x_endian's Avatar
x_endian
Default Order Change
Can you make modification on the spec when the order is at 1100?
Old Sep 29, 2015 | 02:48 AM
CaryBob's Avatar
CaryBob
Absolutely. 1100 just means that the dealer has entered the order into the system. He has not ordered it from GM at this point. Until the dealer actually orders the car, you can make all the changes you want.
Old Sep 29, 2015 | 11:43 AM
Zymurgy's Avatar
Zymurgy
Moderator
You can change until you reach 3000, but the change could put you back to the beginning if it is something that is constrained. Non-constrained item changes would likely have no impact.
Old Sep 29, 2015 | 08:24 PM
bob guzzy's Avatar
bob guzzy
Yep, I changed from Shark Gray to Crystal Red.
Old Sep 30, 2015 | 01:35 AM
kevincol's Avatar
kevincol
To Order Change
