Blinking brake light
Old Oct 11, 2015 | 02:30 PM
meyerweb's Avatar
meyerweb
Originally Posted by JerryU
At least there was a response, even though it makes no sense!!
On my C6 you just look out the tail light lenses, unplugged the connector and inserted the device in series with the plug.
There's a reason CorvetteMods has gotten such a bad reputation in online forums, and has so many complaints with the Texas BBB
Old Oct 12, 2015 | 12:30 AM
E.T.D. Corvettes's Avatar
E.T.D. Corvettes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
My local dealership installs Brake Plus on every new car they sell. http://www.brake-plus.com/ On Thursday of this past week, I won a free Brake Plus to be installed on any of my vehicles. Since I purchased my 2014 Stingray from a different dealership, I asked them to install it on my Stingray. The service manager told me that he would have to take the rear bumper cover off my Stingray in order to install it. HOWEVER, the Brake Plus rep was actually at the dealership at the time and told us that there was indeed a way to install it without removing the rear bumper cover. Ten minutes later, Brake Plus was installed on my Stingray! The installation involved removing the passenger side tail light bezel which then provides access to the third brake light cable just to the left of the passenger side tail lights. He pulled it out enough to attach the Brake Plus mechanism and put everything back together. I highly recommend this product because it reportedly reduces the chance of being rear ended by over 40%.
Old Oct 12, 2015 | 11:58 AM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by witch hunt
to me, they're an annoyance typically found on large gals mini-vans. Especially hate being behind one in rush hour or stop & go traffic. Rate these much higher on same scale as the old "Baby on Board" yellow caution sticker or window suction cup.
I bought them for past Corvettes; and it has logic you are unaware of.
The CHMSL flasher will rapidly flash (4-5 times) the light upon first application of brake, but then stay on solid while the brake is still being applied.
There is an internal timer that prohibits repeat flashing again - upon the next application of brake - if it happens too soon after the last one. Lets say you are in 20 minute stop-n-go traffic situation; and you applied the brakes a total of 30 times in this slow-down; the rapid CHMSL flash would only have happened on brake application #1; the next 29 the CHMSL would come on solid.
I contacted the company that made them for Corvettes in the past; the ones that had mating inline connectors. They didn't have one for the C7 with the mating connectors; claimed that car mfgrs use the most bizzare and unique connectors; changing them with each model refresh. Said they simply couldn't find a source for the C7 CHMSL electrical connectors at the moment.
They did have one I could splice in, but I decided to wait. I am always checking out these threads in hopes someone finally is offering one with plug-n-play installation.
Old Oct 12, 2015 | 01:50 PM
meyerweb's Avatar
meyerweb
Thanks Jag. Did he have to cut and splice wires, or does fishing the wire out expose a connector? If splicing, did you notice the wire colors?
Old Oct 12, 2015 | 04:53 PM
2880's Avatar
2880
Originally Posted by RicK T
If you're talking about the 3rd brake light pulser, Corvettemods has one:
http://www.corvettemods.com/C6-C7-Co...y_p_11583.html
Illegal in Virginia
Old Oct 12, 2015 | 05:10 PM
E.T.D. Corvettes
2015 C7 of the Year
I wish I would have watched him do this, but I was inside the showroom at the time. I saw him fish the wires out, and what he was installing had connectors on it, but I think he had to add connectors to the 3rd brake light wires and connect it that way. I'm almost certain there isn't a connector already in place back there.
Old Oct 12, 2015 | 06:14 PM
meyerweb's Avatar
meyerweb
Originally Posted by 2880
Illegal in Virginia
Says who? I ran one for years on my Miata, had cops behind me in traffic many times, and never had a problem. Also pass VA state inspection every year without issue.
Old Oct 12, 2015 | 06:34 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
I recall a post years ago when I had it on my C6. It said that was a misinterpretation of a law that says you can't have a blinking red light! Don't think a few flashes is considered a blinking red light. Can't be sure how it's interpreted in VA law.
Old Oct 12, 2015 | 11:57 PM
witch hunt's Avatar
witch hunt
Default I still say..
[QUOTE=JerryU;1590670623]The better "blinkers" do not repeat blinking if you depress the brake the second time in a short time period! Also better I irritate some conscientious drivers if it provides a better chance of alerting the person behind who is looking at a text message they just received while pulling forward and not seeing the traffic was still not moving freely!
1---if they're even marginally effective, why would such a simple device not be standard equipment?---it's just an annoying gimmick
2---I've never noticed one on a Vette or any "nice" car, again usually on mom's tired mini-van or old Taurus or Toyota
3---what if everybody actually had one of these installed on their vehicle?---with so many constant blinking lights, this would likely have a hypnotizing effect on many drivers, literally lulling them to sleep!!(truer than you may believe)
Old Oct 13, 2015 | 01:05 AM
E.T.D. Corvettes
2015 C7 of the Year
[QUOTE=witch hunt;1590682848]
1 - They are effective. A flashing light always garners more attention than a steady one. A third brake light was not standard equipment until 1986. Just because something isn't standard equipment doesn't mean it isn't useful or effective.
2 - If you're ever behind my Stingray when I hit my brakes, you'll see it.
3 - Mine (Brake Plus) doesn't flash continuously. That's not going to lull anyone to sleep.
Old Oct 13, 2015 | 07:08 AM
2880's Avatar
2880
19VAC30-70 virginia state inspection manual - "Vehicle is not equipped with a rear (tail lamp) or rear lamp combination of an approved type or light assembly does not work as designed by the manufacturer." Just because you have a state inspector that is not doing his job, does not make it legal.
Had a local sheriff ticket for no third brake light on a vehicle that was never equipped with one and wasnt required by the state - point is most local jurisdictions do not know the requirements for state inspections.
Additionally - the manual specifically addresses the CHMSL - 19VAC30-70-190 "The high mount stop lamp must be steady burning and not wired to flash with turn signals or other wig-wag device."
Old Oct 13, 2015 | 08:22 AM
JerryU's Avatar
JerryU
I'll stand by original quote above! With the use of cell phones and worse folks with a "conditioned response like Pavlov's Dog" who "must" look to see who sent them the latest "useless message," I like all the help I can get to keep them off my rear! If it irritates some-so beit!
As mentioned the better devices flash only a few times then are on full. In bumper to bumper traffic they also have a 5 or 10 second window where they do not repeat!
Distracted driving is IMO the riskiest issue I have driving. I'll work hard to keep my 55 year record of never having had an accident with another car!
Old Oct 13, 2015 | 09:23 AM
  #33
Mike Mercury
if ???
when I bought my first C5 (had gone 10 years without a corvette); I heard screeching brakes behind me on occasion. A first I thought it was juvenile ricers trying to clown around by squealing their tires. But waaaaay too often the person behind me wasn't a young punk; instead someone that almost plowed into the back of my new Corvette !!!
The C5 was simply too low, and not being seen easily by drivers behind it. The only tire squealing I haerd after installation was from Mustang owners (who probably still lived in parents basement - trying to feel like a fully grown man by showing off).
could it be because those using them on "nice" cars only install the type that doesn't sit there and blink-blink-blink-blink-blink-blink-blink, and continue to blink-blink-blink-blink... ?
what if everybody actually had one of these installed on their vehicle?---with so many constant blinking lights...
Many fellow Corvette enthusiasts in this thread have tried to be informative, going out of their way to type lengthy responses to accurately mention that the units we have purchased in the past do not operate in this manor. There is nothing "constant" about them. Are you speed-reading/skimming these responses?
Old Oct 13, 2015 | 09:54 AM
  #34
dprestidge's Avatar
dprestidge
Well, I built one for my wife's Miata, in '99. Before that I had build one for my '88 Goldwing. I also built one for my '06 F150. I bought an electronic one for my '08 Vette. I still have all but Goldwing. I don't care if they annoy people, that means they see me. In all that time I have not been hit in the rear, however I have been hit 4 times in the rear in company cars without the flashers, all on the freeway while I was sitting still. Once the guy said "I didn't know you stopped". YOU DON'T WANT TO BE HIT IN THE REAR AT HIGHWAY SPEED ON YOUR SMALL CAR OR MOTORCYCLE. I have built them for friends and people that have pulled me over to know where I got it.
I think the new ones are great. However like seat belts, air bags, helmets, they should be our choice to have them or not. NOT the government.
IF YOU DON'T LIKE THEM DON'T GET ONE!
By the way if you are following someone with one in traffic because you don't know the way. 10 cars can get between you and them and you can still spot them.
I will be putting one on my C7.
Old Oct 13, 2015 | 11:36 AM
  #35
Mike Mercury
Back in the early 80's (yep; I am that old)... one of our programmers owned a small foreign hatchback car, light silver in color. He got smacked twice from behind ... either his car was too small or the color blended in (or a little of both). After the second time in a year, he put bright orange tape on the back of the car, top, sides, bottom. I imagine some thought he was an idiot; but he never got rear-ended after that.
once the federal government passes a law for something like this, you can almost bet money that either:
* it's waaaay too late, should've been done long ago
or
* it's not a valid safety concern; there's politics involved.
Old Oct 13, 2015 | 02:25 PM
  #36
agapsdiver's Avatar
agapsdiver
My local dealership installs Brake Plus on every new car they sell. http://www.brake-plus.com/ I highly recommend this product because it reportedly reduces the chance of being rear ended by over 40%.
jagamajajaran, looked at their website... no picture or description of their products... no way to purchase.... just a little advertising.
Old Oct 13, 2015 | 02:47 PM
  #37
E.T.D. Corvettes
2015 C7 of the Year
I think it's only available through dealerships that offer their product.
To Blinking brake light
Old Oct 13, 2015 | 02:56 PM
  #38
meyerweb's Avatar
meyerweb
Well, like I said. Almost 6 years with one on my Miata and never hassled at inspection or by the police, and had plenty of police, both county and state, witness it. I'll take the chance of getting a warning over the chance of getting rear-ended.
FWIW, mine didn't flash with the turn signals and wasn't a wig-wag device. And I interpret the "does not work as designed" to mean it can't be burnt out or non-functional.
Old Oct 13, 2015 | 03:09 PM
  #39
2880's Avatar
2880
The manual specifically states ..."must be steady burning." That is not open to interpretation. Work as designed means just that - no broken ground wire that causes bulbs to alternately flash, bulbs that get dim when brake is applied etc. Just like front tag laws, you havent been hassled yet.
Old Oct 13, 2015 | 03:15 PM
  #40
C8-Vette's Avatar
C8-Vette
Illegal in Virginia
Standard equipment on some model Mercedes and many motorcycles.
