Interesting dealer mechanic statement
Old Oct 28, 2015 | 11:49 AM
Casey VP26's Avatar
Casey VP26
Default Interesting dealer mechanic statement
I was at the dealer yesterday for what I was told was a mandatory appointment for checking oil and fluid levels.
Medium size dealer with a dedicated mechanic for corvettes. (Great Guy) I told him I might have run the car to the rev limiter (Unintentionally). I am pass my 500 mile break in. He said you can run it to the rev limiter over and over again. He said I want you to understand that you cannot break this car , it will not break, but if it does, Bring it back and we will fix it for you.
I told him I won't forget that.
Old Oct 28, 2015 | 12:06 PM
bob guzzy's Avatar
bob guzzy
Chevrolet would not give you the warranty you got if they thought you could break it.
Years ago if you ran a car low on oil the engine would run until it was dead.
Not now the car wouldn't run if it had low or no oil pressure.
Same thing with limp mode the car will run to get you to a dealer or home but it won't do it in a hurry.
Old Oct 28, 2015 | 12:25 PM
Glen e's Avatar
Glen e
The first thing I would be suspect of is some tech telling me any type of check was "mandatory".
Old Oct 28, 2015 | 12:40 PM
Casey VP26's Avatar
Casey VP26
The word mandatory was my word for the required appointment that was made by my dealer salesman the day I picked up my new car,
No tech said it . I should have said Chevrolet Recommended Appointment. I stand corrected, Thanks
Old Oct 28, 2015 | 12:41 PM
alienranch's Avatar
alienranch
Total BS on mandatory anything from a dealership. I agree with your mechanic and applaud his directness. No worries on redline if the vehicle is in good condition and normal operating parameters.
Old Oct 28, 2015 | 04:20 PM
thrilled's Avatar
thrilled
I'm willing to bet big money your doing 100 mph in 4th,you want to downshift and instead of
Going to 3rd you go to 1st.You can forget about the rev limiter.And they put it on the computer.The dealership is going to fix the blown motor?
Old Oct 28, 2015 | 04:24 PM
MikeLsx's Avatar
MikeLsx
I do think people baby there warrantied cars way to much.
once everything is warmed up, the car is made to take a decent amount of aggressive driving. First day i bought my corvette, it had like 5 miles on it. Better believe that thing it redline that day. The next day also.
Old Oct 28, 2015 | 04:30 PM
NSC5's Avatar
NSC5
Given the many complaints on here about dealerships doing a poor job of PDI the last thing I would complain about is a dealer who wants the customer and car back a short time after initial delivery to touch base and check fluid levels. If the dealer were charging for this visit I would view it differently but from the OP's description this sounds like the sort of proactive customer service many would like to receive.
And I doubt that Casey (or any other rational customer) would expect the dealer to fix the car over an incorrect shift. Common sense says car protective programming and the warranty won't protect against this sort of behavior/abuse anymore than it would provide protection for the owner who decided to enter his C7 into a demolition derby.
Old Oct 28, 2015 | 05:39 PM
thrilled's Avatar
thrilled
I've been told at Bowling Green they rev the cars before they release them.So if there weren't any problems at the factory I don't see where going to the rev limiter would hurt it
When you 1st drive it.
Old Oct 29, 2015 | 03:18 AM
Grimlock13's Avatar
Grimlock13
If you do this it will damage valves, lifters, possible the whole motor trashed. The Rev limiter won't save you in this kind of a case. Manual cars only as the autos won't let you make that gear change with the paddles.
Old Oct 29, 2015 | 07:04 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Odd that they cut cut the drive train warranty almost in half.
Old Oct 29, 2015 | 08:44 AM
SK360's Avatar
SK360
Depends, it's not always a death sentence, many people do it without and side effects. Clutching in pretty quick can save you from damage also depends if the tires slide or grip. Most of us have done it at least once in our lives.
But yeah regular rev limiter is nothing to worry about, you can ride it if you want.
Old Oct 29, 2015 | 09:08 AM
robert miller's Avatar
robert miller
Are they a true corvette dealer. What I mean by this is that dealer ship had the mechanic's to go to BG KY to be shown how to work on the corvette.
I have had my vette to 2 diff chev delers here just for a OBD2 problem both of them said it was good r couldn't find nothing wrong with it. One of the salesman told me to take it to the dealer in murfreeboro tn which is almost 100 miles away.
That none of the mechanic's had gone to BG KY plus to do that each dealer ship had to pay 25,k plus agree to take so many vette each year. He also told me they put the best mechanic ON THE VETTE'S & HOPE THEY COULD FIND THE PROBLEM.
My OBD2 port would not read nothing only thing you could get out of it was reading 11 volts. So I took it down & told the guy they had it back & I was out with in one hour told me the power pin was a little pulled over & not in the male hole.
Old Oct 29, 2015 | 09:20 AM
SK360's Avatar
SK360
The corvette is just a car, no more complicated then any other new car. Any competent mechanic can work on them just fine. The car is designed to be trashed on and the rev limiter is there for a reason. You could drive to work bouncing off of the rev limiter and do no damage to the car.
Old Oct 29, 2015 | 01:26 PM
W88fixer's Avatar
W88fixer
Do as you wish, I consider driving to work on the rev limiter an abusive behavior and if you have issues look in the mirror.
Plus there is a difference in valve train stability between hitting the rev limiter going through the gears and light load on/off the throttle as is likely in traffic. Don
Old Oct 29, 2015 | 02:08 PM
Nuclearranger's Avatar
Nuclearranger
I think the mechanic just meant that, the car is built for racing, don't be afraid to drive the car fast and hard.
Clearly, you don't want to just keep it in first gear and floor it until you get to work. Not only would the engine just get unreasonably hot, your gas mileage might be... 1 or 2...
Old Oct 29, 2015 | 02:11 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
If you mechanically over rev the engine, you can have 100s of itty bitty pieces lurching around in your engine and probably some holes in the block too.
Drive the car to the top of the tach in 2nd and try to hit 3rd, miss and hit 1st. You let the clutch out and BAM! engine destruction!!
Rev limiters will not help you save that engine.
Drive the car in 1st and stay there with your foot buried on the floor. The rev limiter will stop your engine from exploding.
Manual transmissions can be mechanically over-reved and will destroy the engine.
Automatics will tell you to blow it out your donkey if you try to paddle down to a gear that will over-rev the engine.
Elmer
To Interesting dealer mechanic statement
Old Oct 29, 2015 | 03:46 PM
W88fixer's Avatar
W88fixer
My remark was a response to SK360's post not the dealer mechanic. Don
Old Oct 29, 2015 | 09:55 PM
user051728's Avatar
user051728
The car is designed to take abuse. I work in Automotive, the vehicle durability tests are BRUTAL, they abuse the crap out of a car.
That's how they make sure when you abuse it that it won't break.
Mechanical over-rev on a manual is a different story. But riding redline in gear is fine. The engine doesn't care.
Old Oct 29, 2015 | 10:10 PM
SK360's Avatar
SK360
I've hit 1-2-1 and let the clutch fully out before realizing what was going on and the engine was fine, just some hurt pride, these cars aren't weak. lol.
