Motion button
Old Nov 15, 2015 | 01:54 PM
sobie236's Avatar
sobie236
Default Motion button
Can someone correctly explain what the button next to trunk button does? It's under console on right hand side. Thank you
Old Nov 15, 2015 | 01:55 PM
sobie236's Avatar
sobie236
I meant left hand side, sorry
Old Nov 15, 2015 | 02:05 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
I remember to use it every time I jack the car! After one pump on my hydraulic jack, the horn starts beeping! Doesn't take much movement to set it off. Push the button to shut off that feature. Resets when you start the car.
Patches's Avatar
Patches
From the manual:
Inclination Sensor and Intrusion Sensor
In addition to the standard theft-deterrent system features, this system may also have an inclination sensor and intrusion sensor.
Intrusion and Inclination Sensors Disable Switch
It is recommended that the intrusion and inclination sensors be deactivated if pets are left in the vehicle or the vehicle is being transported.
The inclination sensor can set off the alarm if it senses movement of the vehicle, such as a change in vehicle orientation. Unlocking the driver door with the key will not disarm the system or turn off the alarm. The intrusion sensor monitors the vehicle interior, and can activate the alarm if it senses unauthorized entry into the vehicle’s interior
Old Nov 15, 2015 | 02:28 PM
sobie236's Avatar
sobie236
Thank you!
Old Nov 17, 2015 | 05:06 PM
Thanks for the explanation of what that button does.
Old Nov 17, 2015 | 05:13 PM
AKKutz's Avatar
AKKutz
Wow, never knew this. I jacked my car up to install skirts and never set an alarm off!!!! But then again, I didn't know there were buttons located there! You learn so much on this forum!
Old Nov 18, 2015 | 03:09 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
If you had the fob in your pocket, you're all set and don't need to push any buttons.
Old Nov 18, 2015 | 08:15 AM
agapsdiver's Avatar
agapsdiver
Nope....when I jack up my car with the FOB in my pocket the alarm goes off. (i.e. when I have not pressed the above mentioned button)
Old Nov 18, 2015 | 08:46 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Really? Mine never has and I've never used that button either. Lol, I wonder if my alarm even works.
Old Nov 18, 2015 | 10:53 AM
Mike Mercury's Avatar
Mike Mercury
the inside motion detector is disabled if the targa is off, or the vert top down.
With my '15 coupe in the garage with targa installed - but with the windows down.... I threw a hat into the car through the open window - and the alarm went off.
Old Nov 18, 2015 | 11:21 AM
T-Z06-J's Avatar
T-Z06-J
Not true for my car at least. I didn't know the car had a motion detector until I had the roof off and reached iside my car with the keys inside the house. I didnt touch the car, I was reaching for my radar detector and before my hand reached halfway the alarm went off.
Old Nov 18, 2015 | 11:53 AM
JerryU's Avatar
JerryU
Mine is the same. FOB in pocket and one pump on the jack is enough to have it beep! Doesn't take much movement.
Don't think it is a sensitive as the motion detector I installed in my '88. First time I parked in the airport the fellow at the pay booth (always parked my Vette's close to the pay booth, under a light and with a car cover) said it was beeping a lot on a windy night! Set it with less sensitivity after that!
Old Nov 18, 2015 | 11:56 AM
AKKutz's Avatar
AKKutz
Wow, I raised both sides, installed skirts and never had a beep! Can this system be turned off and on? Does this mean I don't have a functioning alarm?
Old Nov 18, 2015 | 11:58 AM
Glen e's Avatar
Glen e
Was your car locked, when you were raising the sides?
Old Nov 18, 2015 | 12:06 PM
AKKutz's Avatar
AKKutz
No, guess that would solve that problem huh?
Old Nov 18, 2015 | 12:25 PM
Woodson's Avatar
Woodson
Yes. I have passive locking set, so I have to unlock my car before doing any work on it. No need to hit the motion button.
To Motion button
Old Nov 18, 2015 | 01:16 PM
tomlink's Avatar
tomlink
I just picked up my C7 last week. I was getting out of the car from lunch today and was wondering what that button was for.
Thanks for asking and thanks for the answer post.
Gotta love CF, what a great resource!
Old Nov 18, 2015 | 02:15 PM
mpuzach's Avatar
mpuzach
The feature is included on 2LTs and 3LTs but not on 1LTs.
Old Nov 18, 2015 | 04:09 PM
meyerweb's Avatar
meyerweb
I think the alarm only arms if the car is locked.
