There are A8 owners, including me, who still have harsh 1-2 shifts after re-flashing and the "learning" procedure.
There is a thread on another C7 forum about this problem. The OP's dealer found that the trans fluid was 1.5 quarts low. Adding fluid solved the problem.
It makes sense that this might cause the problem. Once the transmission heats up the fluid expands, increasing the level. Since it is not easy to check the level (no dip stick), dealers don't normally check it during routine maintenance.
Has anyone else had experience with this solution?
My 2016 started with harsh 1-2 shifts but now, with over 1000 miles, the shifts are much smoother. Other posts indicated a "learning curve" by the transmission.
My Vette shifts are not what I would call "harsh" but there is a noticeable "pause" in the first two shifts from 1st to 2nd when the car has been in the garage all night and the temps are high 30's. It just turned 1000 miles and I am counting on the shifts getting smoother.
4k miles on mine and when I see these posts I'm like "Oh yeah, mine was like that!"
As its been reported here before its a fluid starvation issue. A kit will be released but the transmission will have to be dismantled for the check valve kit installation.
You can't. It's basically a HUGE PITA to try it on your own and the dealership has to check it for you. So, if at any time your Vette is in the shop make it a standard MO that your tranny fluid is checked since you can't do it yourself. Why the engineers designed it this way is beyond me.
