Axle Ratio
I have been searching and searching for this information for 2016 C7 with 8 speed paddle. How do I find out if it has a 2.41:1 axle, or a 2.73:1 axle?
I was reading the manual about shifting speeds when I ran across this. I have looked at all the documentation on the car and on the Internet and can't find out how to determine this. Any help would be appreciated.
Gear Ratios:
...........................A8....Z51A8.. ...MN7...Z51MN7
First gear............... 4.56 .. 4.56 .. 2.66 .. 2.97
Second gear.............. 2.97 .. 2.97 .. 1.78 .. 2.07
Third gear............... 2.08 .. 2.08 .. 1.30 .. 1.43
Fourth gear.............. 1.69 .. 1.69 .. 1.00 .. 1.00
Fifth gear............... 1.27 .. 1.27 .. 0.74 .. 0.71
Sixth gear............... 1.00 .. 1.00 .. 0.50 .. 0.57
Seventh gear............. 0.85 .. 0.85 .. 0.42 .. 0.48
Eighth gear.............. 0.65 .. 0.65 .. .... .. ....
Reverse.................. 3.82 .. 3.82 .. 2.90 .. 2.90
Axle ratio............... 2.41 .. 2.73 .. 3.42 .. 3.42
Overall ratios:
First gear...............10.99 ..12.45 .. 9.10 ..10.16
Second gear.............. 7.16 .. 8.11 .. 6.09 .. 7.08
Third gear............... 5.01 .. 5.68 .. 4.45 .. 4.89
Fourth gear.............. 4.07 .. 4.61 .. 3.42 .. 3.42
Fifth gear............... 3.06 .. 3.47 .. 2.53 .. 2.43
Sixth gear............... 2.41 .. 2.73 .. 1.71 .. 1.95
Seventh gear............. 2.05 .. 2.32 .. 1.44 .. 1.64
Eighth gear.............. 1.57 .. 1.77 .. .... .. ....
You have to look at overall ratios:
Gear Ratios:
Overall ratios:
Gear Ratios:
Overall ratios:
Thanks for posting. In addition you get torque multiplication from the torque converter off the line (as well as some inefficiency and less fun for some of us!)
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
The 3.42 rear gear on the manuals is because of the transmission limitations with their torque capacity(strength of the tailshaft), so the manual transmissions require a higher first gear ratio, and then depend on the lower rear gear ratio, to achieve overall gearing.
If you multiplied the engine's torque 4.56 times( A8 1st gear) and then 3.42 times(rear gear), you would most likely trash the axles and the differential and would most surely fry the stock tires.
It would require a 4.20 rear gear on the C7 Z51 M7 to have the same "off the line" gearing that the Z51 A8 has.
That 12.45 overall gearing in first gear(Z51) is really about as low as you want to go on the street.
