Removable convertible hard top
the construction is very good- the thick cloth fabric is so much better than cheap vinyl used on older models
My only major complaint is the rear window is ridiculously tiny- can't even see the cars directly behind me. Definitely requires careful adjustment of the side mirrors
1. Replaced by the T-Tops.
2. Expense, costly to produce, and coming from the factory they were under warranty and always leaked.
3. Weight was a factor, as the C2 and yes C3 Hard shells were heavy, bulky, and to get a good watertight seal was almost impossible. You also experience a lot of wind noise, as the hard shells were not insulated. Took two people to put one on, and the chances of scratching the paint was almost certain. Attachment hardware was a nightmare. Clamps, flashing, and just the overall design was poor, more of an after thought.
4. The design of the actual car made it difficult for them to couture the hardtop to fit snuggly, and water tight. T-Tops (Targa) made better sense, besides during the mid 70's the convertible was under attack as being dangerous, and became more of a liability for the car makers.
5. As the convertible returned in the 90, after the success of ASC (chop shop) making convertibles from Camaros and Corvettes, and several other new cars, GM decided to make factory convertibles once again, but the technology was more advanced with the material being used, the mechanics, lighter in weight, better insulation, and most of all much easier for the owner to put the top down and put it up MANNUALLY. So after market hardtops for the C4 and C5 was became available but limited runs, not all colors, and they still remained HEAVY, cumbersome, and difficult to attaché, as you needed to modify the car for the secure clips. So the hardtops really did not make a big comeback, although they are out there for the C4 and C5 and I even saw some for the C6.
6. As far as a factory option, never really got the numbers to make it feasible to mass produce these after the C2. People who had them on the C2 did not really like them (I am sure there are some), but for the most part, they were poor quality and design, requiring a lot of time and effort to attach and remove. with a great deal of space to store. Many were scratched while being stored, more then on the car.
Hardtops have always been hard to store, hard to put on and remove, and just not really practical enough. Now with the new C7, and the internal alarm system, advances in aftermarket security devices, and most of all the ease of putting top up and down, newer lightweight material, and the overall reliability, GM will never go the removable Hardtop route again. I highly doubt the Corvette will ever have a hardtop convertible top mechanism, simply because of the weight factor....
Here you have it the history of the Removable Hardtop.
The improvements in soft top technology, has made the old style removable hardtop obsolete. BUT, the built-in hardtops(first used by Ford in 1957 and now used by many manufacturers) are actually as good or even better than the soft tops of today.
What I like about the C1/C2/C3/C4 removable hardtop is the different roof profile when compared to the Targa/fastback. I really liked the C5 Z06 for the same reason. The hardtop also offered more security than a soft top.
All great points made on why it's not offered, and I appreciate all the detailed answers as it's fun to learn new things. The sealing issues was something I never thought about.
Thanks to all for your responses.
On the Corvette, both the soft top and the hardtop had the same sealing problems to the rear deck lid. Unlike a normal convertible that did not have a deck lid, the soft top was always secured at the rear on the normal convertible.
At the windshield, both the hardtop and the soft top had the same clamping design. Both the hardtop and the soft top had the same sealing to the door glass. On the hardtop, it used bolts to secure it to the deck lid whereas the soft top used over center clamps to secure the soft top to the deck lid. Also on the 1956 through 1960, the hardtop used three bolts, whereas the soft top only used two clamps. On the 61 an 62 the hardtop used two hold down bolts.
Watching the Mecum Auction from Austin today, and several C2 convertibles have come across the block with their hard tops on. I've always liked the look of the C1, C2, C3, and C4 convertibles with the hard top.
Thanks!
Yeah, I actually drive mine in the winter.
