4 cylinder mode
Old Dec 31, 2015 | 10:59 PM
  #81
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Well, I guess at some point we'll know the real answer after some forum member that is running one has an issue and their warranty claim is denied as a result.
Old Jan 1, 2016 | 01:20 PM
  #82
xp800's Avatar
xp800
The Range plug has been out for years and used heavily by the 5th gen Camaro crowd. It does not leave any marks on the car...
And I'm not sure what "problems" folks are talking about. My complaints are how intrusive AFM is -by design- in the current implementation. Not the operation itself. There's a delay in the throttle response as it shifts back to V8 mode before doing anything. And the quiet exhaust is exacerbated, even in V8 mode, when the NPP valves close for noise regulation controls.
Do this test if you haven't for A8/6 owners. Put the dash DIC display in the instant econ mode that displays V4/8 operation (Info mode, toggle down 4-5 screens). Now pay attention to how often the car goes into V4 and pay attention to the behavior around throttle applications and the feel/sound of the transitions. Also note that the exhaust is quiet in V4 mode.
Now do the same while paddle shifting in M mode. This keeps V8 but can't prevent the NPP valve closures... So now pull fuse 42 and keep driving in M car will downshift on its own, and you will always hear the V8 sounds... ****It's this mode of operation, if you like all the V8 sounds, that the Range plug (or AFM tuned out) will allow while in D and the fuse pulled.
As I've said before, it's this V8 burble unruffled and without intervention in D that is so much better, IMO, and is IMPOSSIBLE without some tweaking. Again, not subtle once you've experienced the difference.
Old Jan 1, 2016 | 02:49 PM
  #83
Dif's Avatar
Dif
That's my Complaint also.
If it was programmed to Stay in V8 longer, even just a little longer, instead of almost instantly going back to V4 when you let off the throttle, it would be less intrusive and not as noticeable.
The way it's programmed now it wants to run in V4 as much as possible and longer than needed.
Around town doing 30-40 mph if I Lightly accelerate, I almost have to force it with More throttle before it will go back into V8 from V4.
That's when it Lugs, Hesitates, and Vibrates before switching to V8
Old Jan 2, 2016 | 07:50 PM
  #84
HANNY's Avatar
HANNY
Originally Posted by MikeyTX
'Cmon bro. You and I both know that a tune will trash the power train coverage and most aren't going to risk that. It's one thing on our two wheel sleds since the Mo-Co isn't as **** about it seems as GM is.
I understand where youre coming from..... most guys don't want to risk it (having an issue and the dealer not fixing it because the car isn't stock anymore) and I totally get that. Piece of mind for some guys not having to worry about it makes sense for sure. But for me its just not an issue, I bought mine to run hard and enjoy, if theres an issue because of what ive done that's kool.
Question? I did this mod and wondering if the GM tech will notice it if I have a warrantee problem with my engine or other parts under the hood.
Old Jan 3, 2016 | 06:25 PM
  #85
meyerweb's Avatar
meyerweb
I didn't buy mine with an M7 because of the way AFM works on the A8, but I'm sure glad mine won't go into 4 cyl mode unless I want it to.
Old Jan 3, 2016 | 07:18 PM
  #86
JoeCT's Avatar
JoeCT
Default Apollo 13
Little known fact, on Apollo 13 they had an early prototype AFM disabler:
Old Jan 3, 2016 | 07:20 PM
  #87
Red C8 of Jax's Avatar
Red C8 of Jax
Mine does the same, Lugs, Hesitates and even sometimes vibrates my steering wheel. GM advertises the change from V8 to V4 and back as Seamless. Might have to use that advertisement one day. My Impala has AFM and IT DOES go from V6 to V3 and back Seamless.
Old Jan 3, 2016 | 09:25 PM
  #88
Maxie2U's Avatar
Maxie2U
IMO a vibrating steering wheel is another sign how the AFM system badly stresses the engine and drivetrain.
I recently read a couple of articles that discussed how much stress is put on the belt tensioner, drive bearings, camshaft, torque tubes and other engine components as a result of AFM going back & forth between 4 & 8 cylinders.
This is just another reason why I purchased a AFM disabler.
Old Jan 3, 2016 | 09:27 PM
  #89
TEXHAWK0's Avatar
TEXHAWK0
I just put my manual transmission in 6th and set the cruise control.
My last trip to west Texas got 32.9 MPG. No reason to mess with 4 cylinder mode.
Old Jan 3, 2016 | 09:45 PM
  #90
juanvaldez's Avatar
juanvaldez
My Corvette has a 4 cylinder mode?
Old Jan 4, 2016 | 08:53 PM
  #91
bigfainer's Avatar
bigfainer
Originally Posted by Pelee4me
I took the car in to Stingray this morning. Left with a loaner. I too am getting a new transmission/torque converter. I hate that this happened but you can't beat the folks at Stingray.
Did they provide you a corvette for the loaner?
Old Jan 7, 2016 | 06:44 PM
  #92
Pelee4me's Avatar
Pelee4me
No, they gave me a brand new 2016 Camaro. A v6.
Old Jan 7, 2016 | 06:46 PM
  #93
Pelee4me's Avatar
Pelee4me
I picked up the Vette late yesterday. They were able to swap just the torque converter and it runs just fine now. No more issues with V4 mode. Stingray Chevrolet is your friend.
Old Jan 7, 2016 | 11:12 PM
  #94
Maxie2U's Avatar
Maxie2U
You may want to completely disable your car from going in and out of V4 mode with a Range AFM Disabling Device.
Old Jan 14, 2016 | 04:12 PM
  #95
swaterhouse's Avatar
swaterhouse
Originally Posted by dr p
I had the exact same thing in my 2015, took it to dealer, diagnosed as broken torque converter, then ended up replacing entire transmission, picking it up from Stingray Chevrolet today, i'll let you know how it runs after I pick it up.
Same story here. New tranny on order!
Old Jan 14, 2016 | 04:14 PM
  #96
swaterhouse
The dealer said it had nothing to do with the V4 mode. The 8 cylinder mode just masks the problem but it is there in both modes.
