Engine idle
Old Dec 29, 2015 | 10:20 AM
C8-Vette's Avatar
C8-Vette
Default Engine idle
Do any of you feel that the engine idle is slightly rough?
I have a 2016 Z51(all stock)
P.S. My daily driver is a Volt so its probably my imagination.
Old Dec 29, 2015 | 10:35 AM
xp800's Avatar
xp800
Lumpy idle is completely normal.
Old Dec 29, 2015 | 10:37 AM
Hopper12's Avatar
Hopper12
Yep - normal, especially at cold start up. Smooth's out a bit when warm, but still normal. I like it that way. High performance engine - bit of a cammed up idle. That's a good thing!
Old Dec 29, 2015 | 11:05 AM
C8-Vette's Avatar
C8-Vette
Thanks for your responses. I recall my C6 was about the same.
Old Dec 29, 2015 | 11:26 AM
C7HOORAY's Avatar
C7HOORAY
Yep normal. Nature of the beast - and I love it!
Old Dec 29, 2015 | 06:56 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Probably running on 4 cylinders. You think
Old Dec 29, 2015 | 07:27 PM
BUCKNERBUCK2's Avatar
BUCKNERBUCK2
Never idles on 4, only under load.
It's the same cam as the escalade L86 6.2 liter. Probably the least aggressive cam GM has used in a sports car.
Old Dec 29, 2015 | 08:46 PM
mechengr1's Avatar
mechengr1
Has anyone noticed a knocking sound at idle? My fist Vette so not sure if its normal...
Old Dec 29, 2015 | 09:00 PM
BladeSilver2015's Avatar
BladeSilver2015
There is a TSB out on this issue.
http://www.corvetteactioncenter.com/...ation-989.html
Old Dec 29, 2015 | 09:04 PM
bob guzzy's Avatar
bob guzzy
Go have it checked might be as little as the mount needs adjustment or you could be hearing the injectors clicking.
Old Dec 29, 2015 | 09:11 PM
owc6's Avatar
owc6
Yep, if it sounds like a sewing machine, it's normal DI sound.
Old Dec 29, 2015 | 09:52 PM
mechengr1's Avatar
mechengr1
Yup, sounds like a sewing machine...
Old Dec 29, 2015 | 10:37 PM
BUCKNERBUCK2
It's from the pump, not injectors.
Old Dec 29, 2015 | 11:02 PM
meyerweb's Avatar
meyerweb
Originally Posted by BladeSilver2015
That's dated October 2014. I would assume any cars built after that date would have the "fix" done on the assembly line.
To Engine idle
