Copycats?
Old Jan 17, 2016 | 06:21 AM
BladeSilver2015's Avatar
BladeSilver2015
IMO Lexus front ends are all extremely ugly. Every time I see one I think of this:
Old Jan 18, 2016 | 06:43 PM
BLUE1972's Avatar
BLUE1972
Actually it does look like their inspiration.
Sadly based on the look of most of todays designs, I can't weight for the furniture to follow - then the appliances..
Old Jan 18, 2016 | 07:03 PM
Speednet's Avatar
Speednet
It's still a Lexus, so there will be some kind of major recall on an engine component, the exhaust will belch some kind of noxious fumes, the brakes will squeal, and the battery will go dead every six month. At least that's been my experience with two Lexuses so far (the last two I'll ever own).
Old Jan 19, 2016 | 02:55 PM
BLUE1972's Avatar
BLUE1972
it's funny but the wife's Subaru does the same thing after 3 months. No start due to a low / dead battery. I just started my 1980 Chevy truck after sitting 4 months, due to a lot of reasons - warm weather and the vettes out.. etc. It's going to snow Saturday so I will be using the truck. It started on the second try. First 3 seconds fills the carb, second starts the truck.
My neighbor was warming his import, and said I can't believe you're old girl started it's been sitting, I responded -" no computer to tell it that it can't start " and said see you later as I drove off in 12* temp. No warm up needed.
The proposed change to 24 volt electrical systems in 2020 will fix the sitting issue ... hopefully. The current 12 volt system can't handle all the electric items..
Old Jan 19, 2016 | 06:33 PM
VictorBarron's Avatar
VictorBarron
I cant wrap my head around a "sound generator" under the hood. What the hell is that all about?? My Z06 with Corsa X pipe screams. The Vetts don't need any stinking sound generators.
Old Jan 19, 2016 | 06:42 PM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
Copy Cat?!?! Not seeing it myself.....I don't believe it will ever be mistaken for a C7 or even the other way around
Old Jan 20, 2016 | 03:39 PM
BLUE1972's Avatar
BLUE1972
Watch the Ford Mustang commercial and you will understand. The engine sound comes through the radio.
CA has very stringent drive by noise limits, the later 70's Trans Am had the door on the reverse scoop riveted shut to pass in CA.
Some 4x4 tires won't pass. it's amazing...
Old Jan 20, 2016 | 06:00 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Designed by Match box Car Co.
Old Jan 21, 2016 | 02:31 PM
brandin10's Avatar
brandin10
Originally Posted by rcooper
Top light is ugly.
I've heard that somewhere before. LMAO
Old Jan 21, 2016 | 04:12 PM
randuff's Avatar
randuff
Default Not a copy cat
That has been in their concept design since it was show at Geneva in 2013.
