Radio module
Old Jan 12, 2016 | 03:45 PM
Tom 64/67's Avatar
Tom 64/67
Cruising
Default Radio module
Does anyone know where the radio module is located on a 2014 C7 3LT ?
Tom
Old Jan 12, 2016 | 04:40 PM
meyerweb's Avatar
meyerweb
The main component is under the plastic to the left of the driver's legs.
Old Jan 12, 2016 | 05:00 PM
Tom 64/67's Avatar
Tom 64/67
Cruising
Hello.
I think this is the module you are thinking of http://www.ebay.com/itm/2014-2015-Ch...pVbffz&vxp=mtr .
The module I am looking for is this one http://www.ebay.com/itm/161911231492?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT .
I can not see this module on the left side.
Tom
Old Jan 12, 2016 | 06:06 PM
monicatomokc's Avatar
monicatomokc
Originally Posted by Tom 64/67
Hello.
The module I am looking for is this one Corvette C7 Cadillac XTS Escalade Radio Receiver Module '14 '15 | eBay .
Tom
I believe it is behind the radio and to the right from what I can tell.
Old Jan 12, 2016 | 11:24 PM
Tom 64/67's Avatar
Tom 64/67
Cruising
Thank you, I think I will find it now.
Tom
Old Jan 13, 2016 | 03:18 AM
Weasel's Avatar
Weasel
When the message says "Check XM antenna" where do I look?
Old Jan 13, 2016 | 10:15 AM
DAFFYDRUNK's Avatar
DAFFYDRUNK
Tom
I've also read it's in the dash somewhere behind the infotainment screen. Never seen it though. If you get to it, tell us how much of a pain it is. Looks like lots of dash has to come apart. I know if you want to put the 16 intainment in a 14 and 15 you have to replace this in addition to the HMI. I might do it when Android Auto comes out and doesn't suck. The HMI is easy enough to swap though...
Old Jan 13, 2016 | 03:53 PM
Tom 64/67's Avatar
Tom 64/67
Cruising
The radio module was on the floor,same place as the fuse box on C5, under the floormat. It is two modules there, this one was on the inside of the first module you see. It is hard to see inside the first module.
Tom
Old Jan 13, 2016 | 04:18 PM
monicatomokc
Are you saying it is on the floor, behind the floor mat on the passenger side? Any chance you could send a picture?? That part diagram really isn't that definitive and led me to thinking it was behind the radio.
Thanks.
Old Jan 13, 2016 | 05:23 PM
Tom 64/67's Avatar
Tom 64/67
Cruising
Yes. It was on the floor, behind the floormat on the passenger side. I`m sorry i don`t have a picture of it. I was helping i friend with his C7, and I am not going to see the car for a while. I also thought it was behind the radio.
Tom
Old Jan 13, 2016 | 06:30 PM
monicatomokc
Tom
No problem Tom. When I got home from work today, I checked it out on mine (I just happen to have the trim and glove box out for some other work), pulled back the floor mat and there it was!! I've been thinking of upgrading to get Apple CarPlay and needed to know where that module was located too. THANKS!!
Tom
Old Mar 18, 2016 | 11:45 PM
jfinkow's Avatar
jfinkow
Tom
Thank you both. FYI, Android Auto just came out. A new radio module, along with a new HMI module, will get you both Apple Car Play and Android Auto. But both the HMI and the Radio modules still have to be installed. This thread and your posts makes that radio module install a whole lot easier! Thanks again.
To Radio module
