AFE intake
https://www.corvetteforum.com/forums...e-install.html
Love the sound the 8.2 Liter BB makes in my street rod at WOT! It does have a larger area K&N filter (14 inch OD, 5 inches high) but it also has to compete with straight thru Borlas and 3 inch pipes from long tube headers. The intake makes as much "noise" as the exhaust at WOT in the street rod. The extra sound is very noticeable from the aFe I installed in my C7.
You said you would answer the question for all the previous posters who said it won't produce "any more power," and you did!
Yep a quality aftermarket company can engineer a less restrictive intake when not being constrained by noise limits and filter/air duct costs, etc.
Bet many of those naysayers paid $1195 for NPP to get 5 hp and more "noise." On that basis the ~$500 for the 9 hp achieved with the aFe is a 4.3 times better investment!!
I used the aFe oil impregnated filter that has an even lower flow restriction for probably another few hp! As you said previously, because of possible warranty issues your installer will only use the somewhat more restrictive dry filter option from aFe.
I understand that approach, and their concern. Unless you are very careful when oiling the filter after a cleaning it could cause a problem with the mass airflow sensor! (Reminds me of my Zaino applications - a little goes a long way and excess creates removal problems!)
I have understood how to oil my K&N filters for many years and did not have an issue with prior Vette's or my 2 modified trucks when between Vettes. Also I'm sure many folks with dry sumps who have had oil dripping from the filter due to dealer overfills did not have their sensor replaced by the dealer! Don't recall any saying it tripped codes.
I probably gained a few more hp since I opted for the lower restriction oiled filter option. Actually, like my NPP the increased sucking sound at WOT paid for the investment!
For me, as others have said, the improved under hood appearance and sound are worth it even if the gains are relatively modest.
https://www.corvetteforum.com/forums...eaponx-tb.html
In fact, I did spring for the NPP (again). Why? The sound it offers is worth an easy $1,200 to me. I would have bought it even if it added 0 HP. Increasing HP is not important to everyone. And this is why I didn't spring for the Z06. I simply could care less if my Vette has 460 HP or 650 HP. Heck, my daily driver has only 200 HP (AFAIK). Different strokes....
Had them stacked to the celling over Black Friday and Cyber
Monday - Every one of them was gone by Saturday night
http://www.customcorvetteaccessories.com/afepower.html
Regards
Chip
Regards
Chip
