Exhausted with this!
Old Jan 17, 2016 | 08:26 PM
  #41
drjcw24's Avatar
drjcw24
Originally Posted by meyerweb
What "valve issue"? With the fuse pulled, how can the valves be an issue?
When it goes from 8 to 4 cylinder pulling the fuse just makes it sound awful (imo, to each his own), and exacerbates the switch over. With the fuse in place its as quiet as a prius in 4c mode. Lose lose situation for what I was looking for.
Yes its an A8, and no I didn't pull the wrong fuse or get a CEL.
Old Jan 17, 2016 | 09:53 PM
  #42
meyerweb's Avatar
meyerweb
Originally Posted by carllangford
42 in the 2016 appears to be "Exhaust Valve 2". For the 2014 that appears to be fuse 41 which is labeled the same. Correct?
Correct.
Old Jan 18, 2016 | 01:21 AM
  #43
xp800's Avatar
xp800
The Range Tech plug may be worth trying in this case along with the fuse pull. No aftermarket system will make V4 sound good. The M7 folks get great results with just the fuse. The automatic folks have no idea what they're missing until AFM has been disabled and the fuse has been pulled. I've owned both...
Old Jan 29, 2016 | 12:20 PM
  #44
Dale Runkle's Avatar
Dale Runkle
Cruising
Originally Posted by Maxie2U
Yes, you are missing something on the 2016 model. Besides being able to link driver mode to exhaust settings you can also select which exhaust sound you want all the time by going into vehicle setting then select sound management where you can turn on auto sound management, stealth sound, sport sound, track sound.
how do you get to sound management? I go to settings and there's no selection 2016 c7
Old Jan 29, 2016 | 12:25 PM
  #45
joemessman's Avatar
joemessman
In the Infotainment center settings go to Vehicle and you will see sound management in that interface.
Old Jan 29, 2016 | 03:31 PM
  #46
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Only if he has the NPP.
Old Jan 29, 2016 | 03:42 PM
  #47
carllangford's Avatar
carllangford
Correct.
I wish disabling the CAGS was this easy. I used the "Insert a blown LED-Fuse" method for my C6.
I gather from this post, https://www.corvetteforum.com/forums...-location.html there is no associated fuse.
Old Jan 29, 2016 | 03:45 PM
  #48
joemessman's Avatar
joemessman
Fuse number 42 in the 2016.
Old Jan 29, 2016 | 03:49 PM
  #49
meyerweb's Avatar
meyerweb
That's correct. Spend $20 on a CAGS defeat device, which takes about 10 minutes to install.
He's asking about a CAGS fuse, not the NPP fuse.
Old Jan 29, 2016 | 03:57 PM
  #50
joemessman's Avatar
joemessman
OK. I misunderstood.
Old Jan 29, 2016 | 04:14 PM
  #51
RonnieC6Z's Avatar
RonnieC6Z
Not ALL the time. See post #2.
On the 2016's post # 2 is incorrect. Go into sound management, set the exhaust to track, and it is at its loudest all of the time in every mode. I have a 2016 and it works that way.
Old Jan 29, 2016 | 05:29 PM
  #52
meyerweb's Avatar
meyerweb
Sorry, but even with the exhaust in track mode the valves do NOT stay open all the time. This has been well established. The car would violate federal sound standards and fail the drive by test if it were true.
Old Jan 29, 2016 | 06:13 PM
  #53
Dale Runkle
Cruising
Thanks it works now😎
