Overheating warning
Old Jan 20, 2016 | 12:26 AM
jfinkow's Avatar
jfinkow
Back from Fisher Chevrolet. No codes; no underlying causes found. They think that maybe the thermostat got stuck. They were going to replace it, but did not have one in stock. Driving back from Yuma, I now think that it is the battery. Many weird things were happening, like the center stack rebooting and the steering wheel radio controls not working, as well as the battery gauge needle not pointing where it is supposed to be pointing.
You're right, rrsperry. I should have stopped sooner. I kept thinking that it would self-correct. Especially when the driver info message said to put the engine in idle. So after I pulled over, I did. Didn't help. Lesson learned. See my paragraph above about the battery gauge. Thanks!
Old Jan 20, 2016 | 07:01 AM
NSC5's Avatar
NSC5
A battery issue wouldn't cause fluid out of the coolant overflow line. If system voltage had dropped so far that the electric cooling fan couldn't run then the engine wouldn't have been running either. There could be a tie-in between a defective electric cooling fan motor and the overheat with the fan causing a severe intermittent current draw resulting in other electrical system glitches while not providing cooling airflow but the fan shouldn't be needed for cooling when running at a reasonable road speed.
There have been several reports of C7s with odd intermittent overheating issues and at least one was finally cured after installation of a new water pump. If your local dealer is willing to replace the thermostat I would have it done because:
1. It might be the problem
2 If it overheats again after the thermostat is replaced then one possible cause was ruled out and you are a step closer to resolution PLUS you want to get this addressed early during ownership.
Overheating situations don't self-correct permanently and the next event could be much more inconvenient.
There may be a different issue causing the electrical problem.
Old Jan 20, 2016 | 07:09 AM
jimmyb's Avatar
jimmyb
Another poster had coolant pushing out, I think the OP just got overheat "warnings" in the DIC.
Jimmy
Old Jan 20, 2016 | 02:03 PM
iclick's Avatar
iclick
Originally Posted by jfinkow
Back from Fisher Chevrolet.... Driving back from Yuma, I now think that it is the battery...Many weird things were happening, like the center stack rebooting and the steering wheel radio controls not working, as well as the battery gauge needle not pointing where it is supposed to be pointing.
I don't believe you mentioned what the water-temp gauge indicated at the time of the overheat warning. Put a voltmeter on the battery while the car is running and check the voltage. I'm betting the car wasn't overheating at all but the warning was related to the other problems you describe above, which could be only a matter of low battery voltage.
Old Jan 20, 2016 | 03:44 PM
NSC5's Avatar
NSC5
jimmyb and iclick:
Quoted from jfinkows post #14 on 1/18: " Temp gauge had a pegged temp needle. Got about 4 warning messages. So I stopped, about 80 miles from Yuma. The car released fluid through the overflow."
With the fluid release this appears to be a true overheat and not just an electrical glitch.
Old Jan 20, 2016 | 03:48 PM
jimmyb's Avatar
jimmyb
jimmyb and iclick:
Oops....So I should read the entire post....
Jimmy
EDIT: Nope, I did read it right. You are quoting someone else, the OP does not mention any coolant release
Old Jan 20, 2016 | 04:07 PM
NSC5's Avatar
NSC5
Jimmy
Jimmy,
You are correct, I was responding after the thread split with a second poster who had the coolant loss through the overflow. My post 22 was the response to jfinkow in post 21, I should have quoted his prior post to make that clear.
Rodger
Old Jan 20, 2016 | 05:18 PM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
Originally Posted by 4thC4at60
My '15 C7, from day one, in Texas summers, runs in the 190s - 22,000 miles...
Same with mine here in the Texas heat, usually runs 194-195*
Old Jan 23, 2016 | 01:29 AM
jfinkow's Avatar
jfinkow
Wow. No battery problems!
The overheating was caused by a misshapen surge tank cap. They changed the whole thing: 4031280 Radiator Surge tank replacement
The weird stuff going on with the infotainment screens and stuff? Reflash:
2880178 PI1101 2014 Corvette reprogram BCM, HVAC, Radio, IPC
16953 …per Si doc 3767523
I need to take another long road trip!
