A8 Issues
Old Feb 18, 2016 | 08:06 PM
  #181
REDBULLIT's Avatar
REDBULLIT
Did any of you guys that are having issues experience the 2-1 hard shift? I notice that my car does the 2-1 hard shift only when I drive my car hard, and does not go away until she sits for a long while, I just did the new update not to long ago and still the same.
Old Feb 18, 2016 | 08:17 PM
  #182
Lanbo's Avatar
Lanbo
The Gun Guy
Originally Posted by RODXL1200
There is a fix for this. Ask your dealer when you go in to pull it up. Mine shifted really hard at first shift at start up. After the simple program fix it shifts completely smooth every time.
Did yours do this from day one or did it start doing it later? Mine didn't do it until I had it for a few months. Just curious.
Old Feb 18, 2016 | 11:18 PM
  #183
redlined's Avatar
redlined
Default now what...?
I'm supposed to take delivery of my new 2016 Z51 A8 car this weekend, and I'm stressing out about this TC problem...! Im going to call the dealer first thing tomorrow, and find out the build date. Only problem is, if it is an early 2016 build, what do i do? The loan is processed, checks have been sent, car is insured,...I basically Own the car, just haven't picked it up yet, and now i find out about this....!
Old Feb 19, 2016 | 12:38 AM
  #184
Maxie2U's Avatar
Maxie2U
DON'T FREAK OUT. The odds are in your favor you will NOT encounter any problems with the TC. Don't let it ruin the moment of owning the world's most sort after sports car.
Enjoy the moment...Enjoy your awesome new ride.
Those who did experience a TC problem encounter it when the car goes into V4 mode. That is why I only drive my A8 in manual/paddle shift mode and when I do put it in "D" (automatic) I have the AFM disabler installed so it never seems goes into V4 mode.
Old Feb 19, 2016 | 08:48 AM
  #185
Red C8 of Jax's Avatar
Red C8 of Jax
You have a 5yr/60K mile power train warranty that covers your transmission. Enjoy your car. If you have a problem it is covered. I doubt you will have an early build 2016.
Old Feb 19, 2016 | 09:45 AM
  #186
redlined's Avatar
redlined
Originally Posted by Maxie2U
My 2016 was built on 10/15, wonder how I find out if I actually have the revised tranny or the previous (trouble plagued) revision?
Did you ever get the answer to that question...? Just curious, I'm in the same boat as you.
Old Feb 19, 2016 | 07:23 PM
  #187
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hello REDBULLIT,
I’m sorry to hear that you are experiencing an issue when your vehicle is shifting from 2-1. You mention that you’ve recently had an update done, so I’d be happy to reach out to your dealer in inquire further about your shifting concern.
If you’d like me to assist in this way, please send me a private message with your full contact info, VIN, current mileage, and the name of your involved dealer.
Have a great weekend,
Corey K.
Chevrolet Customer Care
Old Feb 19, 2016 | 08:15 PM
  #188
USCG's Avatar
USCG
Originally Posted by BrittHealey
My 2016 Z51 A8 built August 19, 2015 has very harsh shift when first shifting when driven after start up. Subsequent shifts are ok but first shift is always harsh. My guess is that the torque converter leaks down when the engine is off and the fluid has to repressure before shifts are normal. The 2016 has the auxiliary cooler up front under the front clip and that adds additional fluid that must repressure.
My Stingray A8 was built exactly the same time/same week. 7000 fairly easy miles, altho I've done some aggressive hill climbing/shifting out west with speeds above 120 at times. Some cold weather (20-30 degrees) but no cold transmission fluid issues. Absolutely no problems - but I'll be looking for issues over the next 2-3000 miles if that's when this TC will show it's weaknesses.
Old Jan 8, 2017 | 05:26 PM
  #189
djnice's Avatar
djnice
Originally Posted by \Boost Monkey/
Yes, and also a torque converter (transmission) was what was required because of the stupid AFM. The TC helps to dissipate much of that vibration that is caused from the transition from V8 to V4 and back.
I'm no expert and still learning, myself, but i believe the TC slip is computer controlled to "micro" slip when the AFM transition is made in order to absorb some of the vibrations. A DCT is not able to do this, thus the requirement for a classic torque converter auto.
This is a great transmission, all issues aside. It shifts in auto faster than a dual clutch, even though technically speaking there are alot of similarities between a DCT and this 8L90 that it shifting as fast, or faster, shouldn't be a surprise to anyone.
Good info.
Old Jan 8, 2017 | 05:41 PM
  #190
Scruff Vette's Avatar
Scruff Vette
You need your car's exact build date which you can get from Chevy Cust Service with your VIN. The engineering change was implemented 10/28/2015 per TSB #16-NA-014.
http://www.corvetteactioncenter.com/...-off-1290.html
Old Jan 8, 2017 | 08:25 PM
  #191
Maxie2U's Avatar
Maxie2U
Missed the new tranny by three weeks. Mine was build on 10/5
Old Jan 8, 2017 | 08:32 PM
  #192
joemessman's Avatar
joemessman
I have that info on mine. Specific build date was 10/14/2015. I have just hammered mine to the limits and all is well. 25,000 miles on her.
Old Jan 8, 2017 | 08:39 PM
  #193
Scruff Vette
This is good to hear.
Old Jan 8, 2017 | 09:23 PM
  #194
djnice's Avatar
djnice
This seems to be a consistent comment. People that drive it hard aren't having problems.
Old Jan 8, 2017 | 09:34 PM
  #195
djnice's Avatar
djnice
Above I said this was good info, which it is. One point to clarify, from what I have read related to the DCT, is it does use slip to smooth gear changes and when starting from a stop. It does not appear the DCT systems use the "micro-slip" that in a torque converter trans is done by on-off pulsing of the TC clutch. Anyway, I am not sure a DCT couldn't be used with an AFM system. Keep in mind the AFM in the M7 works fine.
Old Jan 8, 2017 | 09:39 PM
  #196
Jay_Davis's Avatar
Jay_Davis
Nonsense.
