A8 Issues
Old Jan 21, 2016 | 05:21 PM
  #61
DAFFYDRUNK's Avatar
DAFFYDRUNK
Originally Posted by \Boost Monkey/
Yes, and also a torque converter (transmission) was what was required because of the stupid AFM. The TC helps to dissipate much of that vibration that is caused from the transition from V8 to V4 and back.
I'm no expert and still learning, myself, but i believe the TC slip is computer controlled to "micro" slip when the AFM transition is made in order to absorb some of the vibrations. A DCT is not able to do this, thus the requirement for a classic torque converter auto.
This is a great transmission, all issues aside. It shifts in auto faster than a dual clutch, even though technically speaking there are alot of similarities between a DCT and this 8L90 that it shifting as fast, or faster, shouldn't be a surprise to anyone.
They claim it shifts faster than a dual clutch but my money is on Porsche PDK being faster in the real world. Not dissing on the A8, just saying I've driven both and at least the Porsche PDK is more responsive regardless of what GM claims. Also the M7 has noting to dampen the effect of the V4 transitions and it's still not bad. A little more noticeable than the A8 though.
Last edited by DAFFYDRUNK; Jan 21, 2016 at 05:23 PM. Reason: added more blahblahblah...
Old Jan 21, 2016 | 06:01 PM
  #62
Black&White's Avatar
Black&White
Originally Posted by DAFFYDRUNK
I'd be shocked if this was addressed in Ask Tadge. Didn't read the catch can response but I'm sure it was bull$h|t. That dude gets paid a lot of money to lie. I guess I'd lie to thousands too if I could make that kinda bank.
Yes that's why I have not done it before.
Old Jan 21, 2016 | 06:05 PM
  #63
Mobil 1's Avatar
Mobil 1
The newer part # is 24274892. The earlier part# is 24273222.
My 2016 pulls up the newer part # but I suspect the newer part# will pull up for 2015 as well as it has replaced the earlier discountinued part#.
Old Jan 21, 2016 | 07:17 PM
  #64
hanks's Avatar
hanks
The current PDK is absolutely the smoothest auto transmission - double clutch with 2 gear boxes. Porsche nailed it with the current version. I like my A8 but the PDK gear change is incredibly smooth.
Old Jan 22, 2016 | 11:09 AM
  #65
Ernest_T's Avatar
Ernest_T
I tried this yesterday afternoon. I have to drive across the top of a dam to get home so I know there is a mile or so of perfectly level road. I set the cruise on 65 and watched the tachometer. It moved rhythmically between 1400 and 1600 RPM. If it had been a sine wave I'd say it has a period of about 4 seconds--two up and two down. I didn't feel any shudder in the wheel though.
Old Jan 22, 2016 | 11:46 AM
  #66
Mr. Jones's Avatar
Mr. Jones
[QUOTE=Mobil 1;1591373999]The newer part # is 24274892. The earlier part# is 24273222.
Is this number visible on the trans?
Old Jan 22, 2016 | 02:52 PM
  #67
bbcb's Avatar
bbcb
please explain how to find / locate part # ?
Old Jan 22, 2016 | 02:57 PM
  #68
Mobil 1's Avatar
Mobil 1
[QUOTE=Mr. Jones;1591378196]
I would assume so but I don't know where it is. The next time I put mine on the lift I will check.
Old Jan 22, 2016 | 05:48 PM
  #69
Red C8 of Jax's Avatar
Red C8 of Jax
I wouldn't think this is normal but I would just keep an eye out for any steering wheel shudders. Maybe your o-ring has not completely failed. I have also noticed harsh changes between V8 and V4. Chevrolet advertises in the showroom that the switch from V8 to V4 is seamless. Don't think so on my car.
Old Jan 22, 2016 | 08:33 PM
  #70
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
Sute hope this issue is addressed at the Bash this year.
Old Jan 23, 2016 | 05:15 PM
  #71
BrittHealey's Avatar
BrittHealey
Default 2016 A8 1st to 2nd harsh shift
My 2016 Z51 A8 built August 19, 2015 has very harsh shift when first shifting when driven after start up. Subsequent shifts are ok but first shift is always harsh. My guess is that the torque converter leaks down when the engine is off and the fluid has to repressure before shifts are normal. The 2016 has the auxiliary cooler up front under the front clip and that adds additional fluid that must repressure.
Old Jan 23, 2016 | 05:24 PM
  #72
rmorin1249's Avatar
rmorin1249
Similar issue with my late June 2015 build. If this is the only issue I can live with it. If it gets worse I'll have them check it out during my first scheduled oil change. I am curious to know if my tranny is the "new" one or if there is actually any difference between the "old" and "new" ones other than part number.
Old Jan 23, 2016 | 05:35 PM
  #73
joemessman's Avatar
joemessman
Mine has a build date of Oct 2015 and I don't experience any of these harsh shifting issues. Cold or warmed up.
I don't experience this either:
"I tried this yesterday afternoon. I have to drive across the top of a dam to get home so I know there is a mile or so of perfectly level road. I set the cruise on 65 and watched the tachometer. It moved rhythmically between 1400 and 1600 RPM. If it had been a sine wave I'd say it has a period of about 4 seconds--two up and two down. I didn't feel any shudder in the wheel though."
Old Jan 23, 2016 | 07:12 PM
  #74
Black&White
Trust me by now you would know if you had the first version.
Old Jan 23, 2016 | 07:16 PM
  #75
Red C8 of Jax
It has been reported on this forum that the new A8 transmission part # 24274892 was placed in the C-7s starting in October, 2015.
Old Jan 23, 2016 | 07:33 PM
  #76
Gymbow's Avatar
Gymbow
I really wish we could find out what changes were made in the new A8. Is this worth submitting to the 'Ask Tadge' thread?
Old Jan 23, 2016 | 07:45 PM
  #77
rmorin1249's Avatar
rmorin1249
I have a feeling if they take questions at The Bash this year, this issue is going to be brought up.
To A8 Issues
Old Jan 24, 2016 | 05:44 AM
  #78
Parker Corvette's Avatar
Parker Corvette
More C7 troubles. Unbelievable.
Old Jan 24, 2016 | 08:24 AM
  #79
767guy's Avatar
767guy
EXCELLANT IDEA
Old Jan 24, 2016 | 08:34 AM
  #80
bbcb's Avatar
bbcb
gm should do the right thing ...recall the bad tranny's ..
but they most likely will not ....so the owners such as myself ...will be screwed because we put so few miles on the car ...and the real issue will not arise until out of warranty ..
my C7 is stored for the winter less that 400 miles..
it did shift hard 1st to 2nd ... when first starting ..even if i let it warm up ..
