Probably won't be long before Corvette has to have it, tho, given how the CAFE requirements ramp up hard over the next few years.
I agree.
I thought I read a while back that it was going to be put on the C7, but I haven't heard anything else about it recently, and I haven't been on the forum much lately. Thanks!
Originally Posted by Rooster OG
I have a 2016, it doesn't have it.
Great, thanks for your reply and info.
Reason: Merged Posts-please use the Multi-Quote button (middle icon) in the right hand corner of each post.
There really hasn't been much info on this with regard to whether/when it'll come to the C7.
Then again, other than picking up some intel on that from the Bash, I'm not sure how much something like this would be telegraphed by GM.
Excuse my ignorance but what exactly is "start/stop functionality"? I mean when I push the start button it starts. And when I hit the brakes it stops. Somehow I don't think that's what you meant...
Can't imagine having to deal with that, especially when cammed. I have to idle for a few before driving off, even when warm. I don't recall the car being able to start instantly and go when I was stock either.
Not in the US, perhaps for 2017. To meet the new EPA regulations all manufacturers will have to employ everything possible! Better than a turbo V6 engine to me! On average idling uses about 17% of the energy consumed. Our new BMW SUV has it and it works almost seamlessly. It also has regenerative braking that charges the battery so no problem employing the higher electric loads it comsumes.
It starts when you take your foot off the brake and you can't tell. When hot out it will start the engine if stopped for any length of time.
Well worth the effort IMO.
What is it with everyone around here loving to use gas? You just enrich Middle East theocracies for no reason.
If it saves gas and doesn't dent performance a bit, why disable it? Because of ignorance and a belief in automotive conspiracies it'll wreck your engine right when the warranty is up?
A 6.2 liter V8 burns a lot of fuel idling.
I've rented cars with this feature, it's easy as chit to control, all you do is save money.
It's the same reason why the M7's do not have the remote-start function from the key fob like the A8's do...
Here's what I know; they've had this in Europe for years and only on manuals. For manuals it's supposedly easy, car is stopped, clutch is pushed in. As soon as you let off the clutch, the engine starts *instantly* and you would drive normally.
That's why I don't get the indignation here. You can avoid pushing in the clutch when your stopped. On an auto, as soon as you let off the brake, the car starts up instantly.
I would avoid engaging it in traffic and when making a right. But we all know those 3 minute red lights. Those are bad enough, no point in paying a quarter for the privilege of watching hipster cross the street.
Reason: Stupid iPhone
Maybe it's more than "loving to use gas". When it is cold, I need the heater to be functioning and that requires the water pump to be operating. Conversely, when it is hot, I need the A/C running, that requires the compressor. Both the water pump and the compressor require the engine to be running. There are very few weeks around here where it would be acceptable to have either the heater or the A/C shutoff for that long. Any car that has it, I would shut it off and probably never have it turned on.
The way it works is if you are stopped for an extended time it cycles the engine on and off to keep heat and AC consistent. While my car was in getting transmission repair attempts I had a new Impala as a loaner. Its really not that bad IMO.
