C7 front window sun screen
Old Jan 31, 2016 | 09:02 PM
Maxie2U's Avatar
Maxie2U
Default C7 front window sun screen
Does anyone know who makes a front window sun screen that actually fits correctly?
I have not been able to find a sun screen that actually fits the front window. Cover Craft's (UV11325SV) UVS100 Custom Sunscreen for C7 the shade is too tall and will not fit against the windshield leaving a large gap at the top edges. The C7 sun visors do not hold the sun screen in place so it flops / hangs down making the top gap even larger. As such the product will not reduce heat accumulation in the car. Same is true with the GM authorized C7 Corvette Stingray Logo Accordion Style Sunshade.
Old Jan 31, 2016 | 09:04 PM
owc6's Avatar
owc6
And all ears.
Old Jan 31, 2016 | 09:08 PM
-HAIRBALL-'s Avatar
-HAIRBALL-
Mine fits fine...
Old Jan 31, 2016 | 09:12 PM
HAD2HAV2's Avatar
HAD2HAV2
I kept my C6 front window sunshade when I sold the C6 and it fits perfectly in my C7. The visors are not needed but I do push them toward the shade.
Old Jan 31, 2016 | 09:34 PM
Maxie2U's Avatar
Maxie2U
Originally Posted by -HAIRBALL-
Mine fits fine...
Does the top of the shade fit snug against the window? Can't tell by your picture.
Old Jan 31, 2016 | 09:35 PM
Maxie2U's Avatar
Maxie2U
Mine fits fine...
Does the top of the shade fit snug against the window with no gaps in coverage at the top? Can't tell by your picture.
Old Jan 31, 2016 | 09:46 PM
-HAIRBALL-'s Avatar
-HAIRBALL-
Would have to pull it out and try it again, I have not used it since last summer. Does it lay flush right next to the glass all the way across, no. The visors hold it up.
Old Jan 31, 2016 | 09:50 PM
only9balls's Avatar
only9balls
I bought one from HeatShield, they custom make sun shades for all vehicles. The one for my Vette fits well. I have used them in al my vehicles for many years, because they reflect out heat so well, and last so long (I have never had to replace one). The one in my 2006 Tacoma still works great.
heatshieldstore dot com
Last edited by only9balls; Feb 1, 2016 at 10:55 AM. Reason: l;inks to non supporting vendors are not allowed - Sorry... my bad.
Old Jan 31, 2016 | 09:53 PM
itshervette's Avatar
itshervette
Bought mine from the museum. It is cut to fit the window & held in place with the visors. Very little light comes in around it.
Old Jan 31, 2016 | 10:02 PM
Zymurgy's Avatar
Zymurgy
Moderator
I have a Gold Series AutoHeatShield that fits perfectly between the A pillars and the base and header. I don't need to use the visors at all.
Also available with black binding
Old Jan 31, 2016 | 11:36 PM
Maxie2U's Avatar
Maxie2U
How is it held in place at the top? Is it because it is truly custom fit for the C7? Does it sag in the middle?
Old Jan 31, 2016 | 11:57 PM
sdurg24's Avatar
sdurg24
Do you have any photos that show the fit?
Old Feb 1, 2016 | 12:03 AM
Zymurgy's Avatar
Zymurgy
Moderator
It is truly a custom fit. It is supported by the windshield header at the top. There is some sag, but it stays in place because it is supported on all sides (dash on the bottom, A pillars on the sides and the header on the top).
No, I don't, but this is the best fitting sun screen I have ever owned.
Old Feb 1, 2016 | 10:58 AM
only9balls's Avatar
only9balls
They make the best one's I have seen.
Old Feb 1, 2016 | 04:49 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
I have this one and really like it. It fits well and folds up small.
Amazon.com: Premium Car Windshield Folding Spring Sun Shade: Automotive
Last edited by Zymurgy; Feb 1, 2016 at 06:31 PM. Reason: Links to non supporting vendors are not allowed
Old Feb 1, 2016 | 05:26 PM
Maxie2U's Avatar
Maxie2U
I bought a Cover Craft "custom fit" sunscreen for my 2015 Optima which fits like a glove. It fits tight against the windshield and I don't need to use the sun visors to hold the top. I especially liked the construction, material quality and overall thickness of the product. So I decided to buy one for my 2016 C7.
Cover Craft states the P/N I bought is "custom fitted" for the C7 but it does NOT fit. The shade is too tall and will not fit against the windshield leaving a large gap at the top. In fact, the top of the Sunscreen extends beyond the bottom of the windshield header (at the top of the window) by 4"!
The Corvette sun-visors can not hold the sunscreen in place because of the header design so the sunscreen flops / hangs down making the top gap between the windshield and the sunscreen even larger. As such the product will not reduce heat accumulation in the car.
Old Feb 1, 2016 | 05:28 PM
HDBADDOG55's Avatar
HDBADDOG55
That's what I bought, and, it works great.
To C7 front window sun screen
Old Feb 1, 2016 | 07:13 PM
DUPSON's Avatar
DUPSON
Because of all the glass and the transparent roof, I got the California Pop Top. Works great, but not nearly as convenient as a shade.
Old Jun 19, 2016 | 03:25 PM
bigsapper's Avatar
bigsapper
Originally Posted by DUPSON
Because of all the glass and the transparent roof, I got the California Pop Top. Works great, but not nearly as convenient as a shade. https://www.youtube.com/watch?v=SiDwRLh6RE0
I really like this. How well does that material reflect?
Old Jun 19, 2016 | 04:12 PM
DUPSON's Avatar
DUPSON
I believe it is Tyvek. It is white, strong and lightweight. So far, so good. I would buy it again. Easy to use, but it does take a couple of minutes (at most) to put on.
