I found this in my rear tire today. Can't figure how it go there since that part of the tire doesn't seem to touch the ground.
The tire is holding pressure so I'm wondering if I should pull it out or not. Should I not drive the car with it in? If so I guess I should pull it. Also is it repairable?
Sidewall, and close to sidewall punctures should be replaced.
Having said that, I'm sure someone will come in and claim it's fixable, but I don't know an honest or reputable shop that would do it and let you risk a bigger blowout.
First, do NOT pull it out! Bring it to either your dealer or a reputable tire store and have them evaluate it. They will know whether it can be repaired.
And yes, you can drive it to the place to get it repaired as long as you don't pull it out beforehand.
Best of luck.
Too late; I pulled it out. Tire went flat; imagine that. It was a one inch rivet and it was straight. Now I'm thinking of plugging it myself with a plug gun so I can get it to the tire shop although it is a run-flat. Or I could pull the wheel off with my new jack and jack stand. Only 9k miles on these tires, too.
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
No reputable shop can legally repair that.
The argument can be made that a small puncture (don't let to go very long - it won't remain small) does little cord damage and can be plugged, but (1) the owner will have to do it himself or herself, and (2) the owner has to accept full responsibility for any ill effects of having made this decision.
It would not be a good choice for a high speed (read: higher temperatures), track use, or spirited driving in general. I assume that it is a run flat tire? For low risk use (within speed and non-performance parameters), it might be okay, but be very careful.
I plug my own tires, including run flats, and have plugged worse, including one at 22000 miles that I used until it was worn out at 45,500 miles. But I drive very sanely at my stage of life, accept my own risks, and do not place others at risk.
As far as location is concerned, punctures in the tread area of the tire are often repairable. Punctures in the sidewall or shoulder of the tire are not. While it may be physically possible to plug the hole, the flexing of the sidewall is likely to work the repair loose.
Haven't looked past yours and Dave's post below, but you are correct. OP, get ready to replace the tire. Please.
Originally Posted by HalfMoon
Unlikely to repair.
As others have commented, that tire is toast. Too much flex in that area to be able to be successfully repaired. It stinks but it's the only thing you can do. IF it is a runflat you can pull it out - tire will deflate but you'll still get to your local tire shop.
Ok, first.. sorry for high jacking this thread but it kind of applies here..
What do you all do when you have a flat tire with no spare... Do you always use run flat tires??? I've been having that thought, so I thought I'd ask...
You may want to check on the C5 and C6 forums because those guys have gone through a set or two of tires. Some prefer non run-flats because they claim they handle better, make less noise, cost less and so on. However, if you get a flat you'll need to have a flatbed tow the car to have the wheel repaired or have someone pick you up, return with a jack, remove the wheel replace the tire and so on.
I prefer not to let my Corvette get placed on a flatbed (heard some serious horror stories). I don't plan on leaving my Vette on the side of the road unattended. So I use run flats only in my previous C5 and now my C7.
I thought that looked like a rivet from the photo in your first post. It probably fell out of something and was wedged at an angle in the pavement until your tire came along and "harvested" it.
As others have noted this is not safely repairable since it is in the sidewall section where there is too much flex/stress for any patch to be secure and patching attempts in this area create a significant irregularity in the behavior of the part of the sidewall where the patch/additional material is added.
If it is a zero pressure tire just drive it safely at moderate speed to your tire dealer (once you know they have a tire in stock). If it isn't a run flat I would plug and inflate it long enough to get it to dealer but resist the urge to drive it extensively with a plug; tire failure short of an accident can still cause an amazing amount of damage to the body work as it separates and decomposes at speed not to mention damage to an expensive wheel.
If you are home, lift it and pull the wheel when the shop gets the new tire in. Issue you have at this pont is the overall mileage. Do you repair one and then three others later or just replace all 4 now...
Thanks for all of the sage advice, folks. I did indeed manage to patch it with my Stop $ Go tire plug gun which uses mushroom plugs and no glue. It is holding pressure and i just did a short test drive. I've plugged and ridden several motorcycle tires for quite a while so I was thinking this might be fine, especially since it doesn't even hit the pavement, but the comments about tire flex make sense so I'll likely replace it, dammit. Gotta find a place with a no touch tire machine who won't scratch my wheel.
State DOTs won't allow tire shops to patch a sidewall. You'll have to buy a new tire.
If it is a run flat, you should be able to drive to the tire stop. Don't understand why you would need to use a plug gun to get there-that is the purpose of run flats.
