Memory seat function question
Old Feb 23, 2016 | 09:50 AM
NB68's Avatar
NB68
Default Memory seat function question
I have a '14 Corvette and used to have an '08.
Maybe I'm cracking up, but with my '08 I recall, after setting the memory seat position, (setting it to retract all the way when opening the car door for ease of access), I could always then get into the car, press and release the memory button once before starting and it would move me into position.
Now with the '14 once in the car, I have to physically press and hold the button in continuously for it to move the seat into the preset position until it id done??
If I start the car, the then memory seat button will move into position with the 1 touch press-release. But to get into position immediately after entering, prior to starting, I have to press and hold in the button until it is fully positioned.
...That is not the biggest problem in my life right now by far but it is kind of annoying.
So, anyone else notice theirs functions in this manner prior to starting the car?
Just trying to determine if I have a glitch that could be corrected or if this is the new standard button operation.
Thx,
NB
Old Feb 23, 2016 | 09:56 AM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
Pressing the start button once and releasing it will also move the seat, tilt wheel, and mirrors into position.
Old Feb 23, 2016 | 10:14 AM
Zymurgy's Avatar
Zymurgy
Moderator
Only if the 2014 has had the software update to add the Start Button option to memory recall.
Old Feb 23, 2016 | 10:28 AM
RonC7's Avatar
RonC7
There's a whole lot of discussion on seat memory. As delivered, the 2014 seat memory automatic recall was either on or off. On moved the seat when you opened the door. There is a software update the dealer can load to let you select seat movement on door open or engine start.
You can decide how you want your seats to function based on personal preference.
See Post #6 in this thread.
https://www.corvetteforum.com/forums...te-for-m7.html
Ron
Old Feb 23, 2016 | 11:19 AM
Blue Demon's Avatar
Blue Demon
St. Jude Donor '09
Oops, sorry, I didn't notice the 2014 year.
Old Feb 23, 2016 | 11:33 AM
defaria's Avatar
defaria
Having to press and hold the button until everything stops moving is a pain! I don't have to press and hold the button to roll down or up the window, why do I need to do that for the seat?
At least on the C7 you can move from say seat position #1 to seat position #2 while the car is moving. I don't recall being able to do that with my 08. BTW my #2 seat button is my "lean back and cruise the highway" setting.
Old Feb 23, 2016 | 11:34 AM
Glen e's Avatar
Glen e
ginger nailed it...
Old Feb 23, 2016 | 11:38 AM
NB68's Avatar
NB68
Thx
Mine is currently set to move the seat all the way back when opening the door. That was not my issue
I was talking about once in, getting it into the memory position I custom set for the button.
old corvette - 1 push \ release of the button moved me into my desired position.
'14 Corvette - I have to hold the button in for it to move to my preset position...if I let go of the button, it stops wherever it is at until I press and hold it again to finish moving to the custom position.
IF
I choose not to press the button until after I start the car, THEN it will move into position with a single press \ release.
I really want it to follow that press \ release \ fully move into position when first seated with the car off without having to hold in on the button all the time..
Old Feb 23, 2016 | 11:53 AM
TEXHAWK0's Avatar
TEXHAWK0
Originally Posted by NB68
Thx
IF
What you describe is exactly what my 2014 owner's manual says on page 3-4. Car OFF, hold button, car ON, press and release.
Old Feb 23, 2016 | 12:24 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Thx,
NB
Assume you just bought it used! My 2014 was received in September 2013. I had an '08 C6 and was very surprized on how the C7 seat memory worked! Two things made be belive they outsourced the software overseas to someone who didn't drive! About a year after I got my car they offered an optional software. They didn't call it a fix, it still does not allow a one button tuch if you have an M7! It requires you to hit the start button twice.
Here is what I learned to do in that year and IMO it's quicker so I did not bother with the optional software.
When I get in the car I pull the seat belt over to buckle with my R eight hand. I don't waste that right hand movement to hit the start key that moves the seat BUT does not start the car. The belt is also harder to reach with the seat forward
At the same time I use a finger on my left hand to press and hod my memory key untill the seat is forward and the steering wheel lowers. Then with the clutch depressed I hit the start key only once.
Your call, I'm happy with that method!
Old Feb 23, 2016 | 01:35 PM
NB68's Avatar
NB68
Thanks...at least I'm not crazy now that I see this is "normal" operation.
I checked out the video too.
Yep, exactly my problem....w seat all the way back I cannot depress the clutch fully to start.
I'll try your multi-task method solution....It is not my forte though...still learning to walk and chew gum at the same time.
Sol what of this "optional software"? What all would it change \ fix?
Thanks for all the replies!
Old Feb 23, 2016 | 04:17 PM
JerryU's Avatar
JerryU
Some like the optional software. It is standard on the 2016 so you can read operation in the Owner's Manual (free PDF available.). However it is not written well just read slowly!! It should be free.
Wife always accuses me of not "multitasking." So using two hands simultaneously to start the C7 is mine! Been doing it for over two years so it's 2nd nature.
It's like getting my hatch to latch requires a door (or window) to be open. Perhaps yours latches fine, some do. But enough 2014/2015 did not so for 2016 GM put the motorized pull down that was on the C6 back! If it doesn't latch without pressing, be careful, don't press from the center, only with two hands at the edge of the hatch window. A number of reports of paint cracking, probable the biggest reason GM reverted back to a motorized pull-down.
Easy workarounds for a great car.
Old Feb 23, 2016 | 06:43 PM
Redvette_22's Avatar
Redvette_22
I don't know if it is different on a automatic from a manual trans car, but my 2014 A6 seat memory works the same as my 2009 & 2011 GS. When I shut the car off, the seat goes to the "exit" position, when I start the car, the seat goes to the preset drive position. I do not hit any buttons unless I want to get out with the engine running and hit the "exit" button, then when I get back in with the engine still running I must "tap" the memory button for my preset position, but I don't have to hold it at anytime. I bought my car used this past December, and according to all Chevrolet records, it has never had any computer upgrades.
Old Feb 23, 2016 | 06:52 PM
Zymurgy's Avatar
Zymurgy
Moderator
Thx
IF
With the software update, you can set the memory recall to work when you press the start button (you don't have to start the car). When the seat has moved forward, then you can start the car since you can now reach the clutch.
Old Feb 23, 2016 | 08:22 PM
JerryU's Avatar
JerryU
I should have said in a prior post, the seat recall issue is a problem with M7's (not A6's) where you are not tall enough to depress the clutch to start the car with the seat back.
Upon entering, if set properly it will stay in that position when I open the door to get in, until in my case, I press and hold my memory recall button.
Set incorrectly the other irrational thing it does is the seat will go to my FOB set position as soon as the door is opened. That option was apparently for Superman who is faster than a speeding bullet!
As I recall that irrationality was fixed for 2016.
Have never been told why the software was changed from what worked fine in the C6 or why the software "option" wasn't exactly what it was for prior Vette's.
Hence my speculation the seat software was outsourced to someone who didn't drive!
NOT complaining since my two hand method works fine, allows me to use my right hand to first easily reach the seat belt with the seat back and buckle it while I simultaneously push the memory recall button with a finger on my left hand. Since mine is a DD it allows quicker starts. To each his own.
Old Feb 23, 2016 | 09:25 PM
Playboy2's Avatar
Playboy2
Originally Posted by Glen e
Thanks for the video Glen this was my exact issue on my 2015 M7. It was driving me nuts, I didn't realize I had to shut everything off, set and then turn the memory back on. That's why I love this forum
Old Feb 24, 2016 | 09:29 PM
Dave80C3's Avatar
Dave80C3
Well in my 2014, with the software update it does not require me to press the start button twice. If the car is parked in 1st or R, and the e-parking brake was set, I depress the clutch and hit the start button once. The car starts, my seat moves forward, and steering wheel moves down and out. I love it.
I do understand if with the seat all the way back, you can not depress the clutch the start button would have to be pressed twice.
Old Feb 24, 2016 | 09:49 PM
Zymurgy's Avatar
Zymurgy
Moderator
Here is the info from the 2014 software update:
Seat memory recall fix PI1245
GM now has a fix for the seat memory issue. PI1245 Dated 5/20/2014 for cars with manual tranny's. Doc # 3829637
"2014 Chevrolet Corvette | Corvette VIN Y Service Manual 5533811 | Document ID: 3829637
________________________________________
#PI1245: Auto Memory Recall Option Addition for Memory Seat Functions with Manual Transmission Equipped Vehicles - (May 20, 2014)
Subject: Auto Memory Recall Option Addition for Memory Seat Functions with Manual Transmission Equipped Vehicles
Models: 2014 Chevrolet Corvette
Condition/Concern
Some customers may comment that the memory seat moves to the stored memory seat position when the door is opened. Customers would like the seat to move when the ignition is turned on just like the automatic transmission equipped vehicle.
Recommendation/Instructions
Reprogram the seat memory control module with the latest calibrations available on TIS2WEB. Refer to Seat Memory Control Module Programming and Setup (Driver Seat) in SI.
Once the new calibration has been installed, an additional menu option will be available under the remote recall menu found under the "Vehicle", "Comfort and Convenience", "Auto Memory Recall" menu and the new selections are “Off”, “On - Driver Door Open”, “On - At Ignition On.”
Note: For the remote recall memory seat feature to operate, the parking brake must be applied.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
2810875 Driver or Passenger Seat Adjuster Memory Module Reprogramming with SPS Use Published Labor Operation Time
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information."
Old Feb 24, 2016 | 10:07 PM
JerryU's Avatar
JerryU
Yep, the issue for many of us is with seat all the way back pushing the clutch in is not easy! With my prior C6 you just hit the desired memory button one time and the seat, wheel went to the stored position.
Why they changed that for the C7 and added the "feature" of having the seat return when the door was opened when they had a perfectly satisfactory method with the C6 has never been stated.
Frankly, it's like the hatch latching which worked for some cars as designed and not others. They no doubt spent a lot of engineering time trying to make all cars work as designed before reverting to what was used on the C6, a motorized pull down, and were not successful. They no doubt know what the problem is and for whatever reason don't want to say.
To Memory seat function question
