P0455 Code Help !
Old Mar 3, 2016 | 07:26 PM
Rod2013C6's Avatar
Rod2013C6
Default P0455 Code Help !
Okay so in a previous post i stated that i had a P0455 code that is a large evap system leak so went to the dealer today and they pulled vacuum or pressurized the system and found no leak...so i need someone that has been down this road already to tell me what the dealer did to fix this because the service writer said if it comes back on, and it will, they will need to keep the car for several days and try to figure out what is going on and i know that the likely hood of whatever fixed one of your cars is probably the cure for mine so please respond with a part number if you would...Thanks
