Car dead
Old Mar 4, 2016 | 06:52 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by themonk
so no power at all but the electric windows worked.
Old Mar 4, 2016 | 07:00 AM
C7Joy's Avatar
C7Joy
Interested to see how this plays out....
Old Mar 4, 2016 | 07:32 AM
Black&White's Avatar
Black&White
Maybe the Engine is locked up. Many 2014s as I recall did this when the engine failed. Of course it won't crank if the motor has welded itself solid.
Old Mar 4, 2016 | 07:45 AM
Dads dream's Avatar
Dads dream
Old Mar 4, 2016 | 10:36 AM
seCen's Avatar
seCen
Originally Posted by 15Stingray
That is very concerning the manual door release did not work?'
Can u please tell me exactly where u reached for the manual release?
I've owned C6 and now C7. With a dead battery I have opened the doors with manual release.
It was my first time pulling that lever. I pulled it, then I think I heard a clunk then the door released from the lock but when I go to push the door button or the door itself, the door wouldnt open. Maybe I didnt pull it right or something but Im not trying to troll here.
Originally Posted by Frodo
Things don't seem to add up here. Not saying the OP isn't correct in his observation of events, its just having an electrical problem that leaves the car partially powered followed immediately with a mechanical failure of the manual door release doesn't add up. In my career as a business machine repairman I've seen problems that baffled the mind but made sense once solved.
Anyway, my first thought is that power to the front fuse panel may have been lost. You mentioned having repair work done to the engine, perhaps the mechanic left something loose, like the main power cable from the back, or partly dislodged the fuse panel. The whole fuse panel simply unplugs from its mounting base. That's what the 2 lock levers are for. That might also cause other problems you've mentioned, caused perhaps by an intermittent electrical connection.
Good luck with this repair and let us know what the dealer says was wrong. We'd all like to know.
Well, thankfully it happened in a residential area and not the interstate. Will most definitely post up the service receipt when I get the car back.
Even though the engine failed, should the electronics in the car still work? I was left baffled as to how could something like that happen.
Old Mar 4, 2016 | 10:38 AM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
WTF are you talking about? "Many" 2014 C7s had engines that locked up and welded themselves solid? Where do you get your insane ideas and info?
OP, do yourself a favor and don't put any stock in anything this guy posts.
Old Mar 4, 2016 | 10:43 AM
Black&White
Yup true, many many blown motors in 2014. In fact Car and Driver had two blow on them. Here is one of my friends cars. Blew to smithereens with 7k on the clock, Go ahead PM him Forum member Mango727. It's old news.
Old Mar 4, 2016 | 10:47 AM
Red C8 of Jax's Avatar
Red C8 of Jax
Originally Posted by seCen
I hope its the ecm thats causing the poor shifting/jerkyness and bad gas mileage. I did notice that I had bad gas mileage when I got the car back from the dealer.
If you have an A8 as I have, a bad torque converter caused my jerkiness, poor shifting, shuddering and bad gas mileage. All this went away with my new torque converter.
Old Mar 4, 2016 | 10:53 AM
Boiler_81's Avatar
Boiler_81
When the manual latch pulled, you should just push on the door. Pushing on the release button does nothing.
Steve_R's Avatar
Steve_R
They sold about 37,000 C7s in 2014. Got any stats, with source, for how many "blown" engines there were the first year?
No? Didn't think so.
The three you refer to above aren't "many, many" out of 37,000. That's 0.008%, or 8 thousandths of one percent. Yeah, that's a HUGE problem. Based on this and your A8 rants you obviously flunked first year statistics.
Old Mar 4, 2016 | 10:55 AM
seCen's Avatar
seCen
Funny thing about that was, I told the service lady that but all they did was update the software to the trans. There are no more park to 1st hard shifts anymore but put it into reverse, it jerks and it shifts rough when driving normally. Will call them today to tell them about the trans while the car is still there.
Old Mar 4, 2016 | 10:57 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
If the window doesn't index, opening the door may take a pretty good push to get out.
I'd definitely try the emergency release again and this time push it with conviction.
Elmer
Old Mar 4, 2016 | 11:02 AM
  #33
Black&White
Sweetheart do your homework before spewing your crap. Many engine replacements listed on this Forum. Click below.
http://www.autoevolution.com/news/c7...deo-97115.html
Old Mar 4, 2016 | 11:04 AM
  #34
\Boost Monkey/'s Avatar
\Boost Monkey/
No, i would think the trans/mileage issues are not related to your car crapping out, that is something else.
The fact that the car completely shut down, wouldn't even give you ACC power when you pressed start button, yet you still had power from the battery sounds to me like a massive failure of the ECM or the BUS communication system between all of the modules. It doesn't really sound like a mechanical problem to me.
Old Mar 4, 2016 | 11:23 AM
  #35
Steve_R's Avatar
Steve_R
Yup, another website that links back here, with no numbers of "blown" engines or source of information provided. That might be called "homework" where you come from, but not in my world. It's meaningless drivel with no statistical validity whatsoever. Try again.
Once you come up with a real number let's do the math to calculate the % of "blown" engines. It's easy math. Then we'll see if it's the huge problem you seem to think or if it constitutes "many, many" or not.
Old Mar 4, 2016 | 11:46 AM
  #36
DickieDoo's Avatar
DickieDoo
Elmer
PULL not push...... just like the hood latch
Old Mar 4, 2016 | 11:50 AM
  #37
eboggs_jkvl
Moderator emeritus
I meant PUSH the door outward with force, not push the lever. I thought my information was pretty specific as I said, "opening the door may take a pretty good push". I say this because the window might be pressing up against the rubber gasket if it does not "index". The lever also needs to come up pretty far to get the door to open.
Elmer
To Car dead
Old Mar 4, 2016 | 12:11 PM
  #38
seCen's Avatar
seCen
Your explanation does make it seems like that is likely the culprit. Called the service lady and shes away from her desk. Hope the mechanic got around to looking at it.
Elmer
Prior to this incident, there were several occurrence where the door wouldnt open after pressed the door open button. I literally had to tackle the door for it to open. Im sure this door release lever not working properly is me not doing it right.
Old Mar 4, 2016 | 12:37 PM
  #39
Curahee's Avatar
Curahee
Steve is obviously having a bad day. Let's all join hands electronically and give him an e-hug.
Old Mar 4, 2016 | 12:55 PM
  #40
Steve_R's Avatar
Steve_R
I appreciate the thought, but I'm actually having a pretty good day. I just hate to see rumors, speculation and conjecture passed along as fact here, which is unfortunately not unique to this forum.
