So... After 16 hours of wrenching, I have finished installing my long-tube headers and x-pipe.
I drove the car for about 45mins, and BOOM.. Check Engine Light comes on. I scanned it when I got home, and sure enough it was complaining about low catalyst efficiency.
What did I miss? I installed O2 spacers on the 2 downstream O2 sensors....
I was under the understanding that only American Racing mid length with cats are the only ones that won't throw a code.
I put the LG LT headers on my car with LG mid pipe also. pulled off the back cats, but did get the front cats from LG my check engine light also came on. My car was running way to rich but I put on the above also put in the car cold air box & T.B. spacer.
Now my car is running better and faster also plus I check plugs now the plus are not running black & rich now running light brown.
not sure what you mean about o2 spacers? could go into what code is all about but its boring. might hit me up about the spacer deal and I could hel pyou out. paul
O2 spacer is designed to pull the oxygen sensor farther from the exhaust for use when deleting cats on a car. It tricks the o2 sensor into thinking there is still a cat by reducing the amount of air the downstream sensor reads. I've used these on several of my cars in the past with no issue. This is the first time it didn't seem to work and car got a CEL.
I also installed a wideband O2 sensor for monitoring my air fuel ratio's. I haven't started logging of the car yet to see if it's picking up any knock, but initial air fuel doesn't seem bad. Are people only required to tune with long tube headers just because of the check engine light? Or is there actually a problem with knock because of changed load? With the weather being crappy the next few days, I won't get a chance to get out and log the car, so it will stay parked for now
Everyone keeps saying "needs a tune". I understand that, but can someone please elaborate on that? Does the car just need the CEL disabled from the ECU, or are there actually driving/load parameters that need to be modified. Since the car will be parked the next few days before I can take it out and data log it, I can only speculate right now.
Had this with my C6, LT ARH and High flow cats. The tuner can set the O2 sensors to the OK mode. Figured since he was there a full tune wouldn't hurt. Car ran great for years without the CEL coming back on and passing our state inspections. Don't know if the C7 is the same as the C6 as for tuning but the tuner should be able to set those sensors.
Yes, a tuner will tune out the rear O2 sensors. The problem is long tubes move the rear O2 sensors back so they don't get hot enough. People claim the Diablow tuner does not leave any trace that GM would find if you flashed back but I'd confirm first.
Guys... I have a tuner. I picked up an HP Tuner setup and have the car parked. I haven't been driving it aside from a trip around town light throttle. I can tell you that based on the wideband readings I was seeing though, the car didn't seem to be running dangerously lean. I was simply asking what is the reason for needing a tune. I appreciate the input and don't plan on beating on the car until I do some data logging and tuning.
oh boy... plz tell me your not planning on tuning your own car also now.
