Missing 0-60 Performance timer issue SOLVED
Old Mar 17, 2016 | 03:24 PM
randuff's Avatar
randuff
Default Missing 0-60 Performance timer issue SOLVED
Please have your dealer refer to GM Bulletin # 15814 that came out this month.
This will instruct the dealers of the fix in the IPC (Instrument Panel Cluster) of reprogramming the computer.
You're welcome
I will add this.... My car does not have the performance timer but my VIN also does not show up as a Required Field Action for this fix.... Trying to figure that out.
Old Mar 17, 2016 | 03:35 PM
Boiler_81's Avatar
Boiler_81
Awesome, when I take mine in for the Android Auto update, I will get this one at the same time.
Old Mar 17, 2016 | 03:45 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Thanks, this is great! I'm gonna bring mine in for this, android auto and my right front turn led's went out. I wonder if I can get them to put the z06 grille I got in at the same time, I'm pretty sure they have to pull the whole nose for that anyway.
Thanks again!
Old Mar 17, 2016 | 04:09 PM
defaria's Avatar
defaria
Excuse me but could you please explain what the issue was and how it was solved. I don't know what GM Bulletin # 15814 is.
Thanks.
Old Mar 17, 2016 | 04:18 PM
randuff's Avatar
randuff
Thanks.
Some 16 C7s were missing the 0-60 performance timer in the Driver Info Center. This is just a software update that adds it back.
Old Mar 17, 2016 | 05:15 PM
l.i. bruce fan's Avatar
l.i. bruce fan
Any idea how long the software update will take my local service tech to perform?
Old Mar 17, 2016 | 05:24 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
If I had to guess just based on threads I've read about similar updates, anywhere from one hour to two weeks and up to four visits.
Old Mar 17, 2016 | 06:15 PM
BEZ06's Avatar
BEZ06
My brand new C7 has the "Performance Timer", but not the "Lap Timer".
Apparently the reprogramming adds the Perf Timer, but still does not bring back the Lap Timer!!
Old Mar 17, 2016 | 08:03 PM
Gymbow's Avatar
Gymbow
Anyone have a link to the bulletin?
Old Mar 22, 2016 | 04:53 PM
daleong's Avatar
daleong
Bump - anyone??
Old Mar 22, 2016 | 09:44 PM
tail_lights's Avatar
tail_lights
I requested my dealer do the update as I got my oil change (and Android Auto). I haven't tried to test it out but it does show on the screen now. It is a bit different than the '15 because my '15 I couldn't do a 30-130, it set the higher one at a 125 limit, this one goes to at least 135
Old Mar 23, 2016 | 12:27 AM
T-TOP TOM's Avatar
T-TOP TOM
Originally Posted by tail_lights
i requested my dealer do the update as i got my oil change (and android auto). I haven't tried to test it out but it does show on the screen now. It is a bit different than the '15 because my '15 i couldn't do a 30-130, it set the higher one at a 125 limit, this one goes to at least 135
how long did it take to have updates installed?
Old Mar 23, 2016 | 04:15 PM
tail_lights
With an oil change, the Android update and the timer software my total time at the dealer was 4.5 hours
Well..... It lets you go all the way up to 250, however, if you select anything over 125 it defaults back to 125. How disappointing... I was hoping to get 30-130 runs timed.
Old Mar 23, 2016 | 05:49 PM
Streetrod782's Avatar
Streetrod782
Just had my update done on Monday and with and oil change I was there 3.5 hours so bring a book.
Old Apr 3, 2016 | 07:21 PM
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
I'm getting close to my first oil change so I sure hope Criswell is familiar with this issue as well as Android Auto and an A-8 reflash. They sell and service a lot of Corvettes so I am fairly confident they will do the job right the first time.
Old Apr 9, 2016 | 09:24 PM
wrecker3's Avatar
wrecker3
I had the Performance Timer update done today along with the Android Auto upgrade. It took 90 mins to do and the tech showed me how to set it up.
Old Apr 14, 2016 | 09:02 PM
daleong's Avatar
daleong
I had mine done today at Henna Chevrolet in Austin. No issues... Just had to reset some of my dash settings and re-pair my phone on Bluetooth.
To Missing 0-60 Performance timer issue SOLVED
Old Jan 26, 2021 | 03:21 PM
JasonVette's Avatar
JasonVette
I need this done, but the car is out of warranty. How much do you think a dealer would charge for it?
Probably will just save the hassle and get a dragy instead.
Old Aug 16, 2021 | 07:31 PM
cobratraxxas's Avatar
cobratraxxas
Hi all, I have a 2016 C7 M7 non-Z51 1LT that didn't come with the 0-60 MPH timer. The car is at the dealer right now. The dealer tech said that mine wasn't supposed to have the Performance Timer based on my VIN. Is this valid? Do any 2016 C7 M7 1LTs (non-Z51, non-ZO6) come with the 0-60 timer?
Does anybody here have a 2016 C7 M7 non-Z51 1LT that either came with the 0-60 timer or that didn't come with the timer but you were able to update your car to get one at the dealer?
Old Aug 17, 2021 | 08:25 AM
mtb2015's Avatar
mtb2015
This may be a dumb question. I have 2015 z51 1lt Do I have this timer and if I do how do I locate it. When I bought the car never was taught much on all the things it can do.
