Overheating question
Old Mar 20, 2016 | 05:13 PM
  #41
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
^^^ My thoughts exactly. Brings back a lot of memories.
Old Mar 21, 2016 | 09:20 AM
  #42
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Originally Posted by Rob4092xx
Uncirculated water sits in the heater core and hoses when the heat is not turned on. This water is cool since it is not circulating through the engine when the heater is off.
The reason for turning on the heater on is the cooler coolant in the heater core and hoses mixes in with the overheated coolant cooling it down. In other words turning the heater on introduces more coolant into the system.
Makes no difference if you turn the heater blower on high or low. Just turning the heater on introduces the water into the coolant system.
This is why your heater air in the cabin does not warm up until the engine reaches normal operating temperature. The coolant in the engine circulates through the heater core and hoses and this is what the blower uses to introduce warm/hot air into the cabin to warm you up. The blower blows air through the heater core, through your vents into the cabin.
WRONG!
Heaters have been full flow since 1963.
Old Mar 21, 2016 | 12:56 PM
  #43
DBott1234's Avatar
DBott1234
Man this thread went all over the place. The car is in the shop and I'm supposed to get a phone call this afternoon. Will keep the thread updated.
Old Mar 22, 2016 | 02:05 PM
  #44
DBott1234's Avatar
DBott1234
Fast forward 24 hours and they said everything looks fine. Checked all the lines, fluids etc. and said everything came back fine. Weren't any codes left when overheated either.
He asked me if a service tech could take it home with him tonight (service tech lives about 25 miles away) to try and recreate the situation that it overheated on the highway. I said absolutely not and laughed. Did he really think I was going to say yes?
Sorry I don't have any answers to report, that's all I've got for now. If it checks out with them, I'm fine with it. It'll be for sale in the next month anyways, I'm done with it.
Old Mar 22, 2016 | 03:17 PM
  #45
SRQStingray's Avatar
SRQStingray
Originally Posted by PegasusCapital
I'm not sure of the purpose of turning the heater on, but now that you have it at home it doesn't make any difference.
Dissipates heat, an old fix for overheating but a miserable drive.
Old May 1, 2018 | 10:03 PM
  #46
14 Stingray's Avatar
14 Stingray
I have had same issue. I have a 2014 Z51 and was coming home from the Bash at the museum on Sunday. Made two stops for gas and lunch. Got 3 miles from my exit and hit construction traffic, stop and go, turned off A/C to try and assist cooling by running heater, no help. Pulled over to parking lot, was starting to lose oil pressure, cut off car, opened the hood, fan not running. Tried to restart, acted like a low battery, difficult to turn over. Let the car sit for a while, engine started with a check engine light. Fan still did not come on until I turned on A/C again. Car drove home ok.
Next morning, on Monday, I drive car to dealer, no check engine light. Dealer calls me today for more info because.............you guessed it, failure to replicate.
Has happened to me at least two other times. Once I had a Master GM Tech connect a device to the car and sent command to the fan to run at 100% and fan responded, so we know that the does run when commanded, Just have to find out why the car is not telling the fan to run.
