Is GM ignoring Bluetooth issues?
Old Mar 26, 2016 | 06:15 PM
z51vett's Avatar
z51vett
9.3 fixes your problems there is an issue but can't remember what is is they are working right away to update with fix. I have 16 SS and that fixed my 9.2 problems my 16 Z06 is not here yet but my 15 z51 had problems after 9.2 update.
z51vett
Doug
Old Mar 26, 2016 | 06:30 PM
raylo's Avatar
raylo
9.3 fixed the BT issues on my 2016. It was Apple, not Chevy, after all.
z51vett
Doug
Old Mar 26, 2016 | 08:37 PM
Richard Ames's Avatar
Richard Ames
Originally Posted by joemessman
I presume it is the same model iPhone?
Yes it is the same model. We have an appointment with the Apple Store to either fix or get the new one that comes out Wendsday the same size as our 5's. May go to a 6s instead.
Old Mar 26, 2016 | 09:05 PM
z51vett's Avatar
z51vett
It was Apples 9.2 that fouled everything up. 9.3 is the fix.
z51vett
Doug
Old Mar 26, 2016 | 09:24 PM
Richard Ames
z51vett
Doug
Seems one phone. Mine it is a hardware issue. $269 to fix or go latest greatest is our decision.
Old Mar 27, 2016 | 10:23 AM
joemessman's Avatar
joemessman
Yes. I like the 4 inch iPhone too. For what I do with it, like run, ride bicycles and things like that the more compact size suits me. The iPhone for my wife is a replacement for her computer, so the larger display is perfect for her. But the battery life on the larger 6s is quite a bit better.
Old Mar 27, 2016 | 03:33 PM
Formula52's Avatar
Formula52
Depends on which version of the phone you have too. Some of the older versions of the iphone don't play well with ios 9.xxx
Very true. They just halted the download and are working on a fix for the older versions. Seems it asked for the original password and login and many people with older versions do not remember it...
A fix should be available in a few days....
Old Mar 27, 2016 | 05:08 PM
bluman's Avatar
bluman
As folks above said, upgrade to 9.3 cured the issue.
Old Mar 27, 2016 | 06:41 PM
Richard Ames
As stated above. Did Factory restore, 9.3 OS unpair and repair. It did fix the source issue.
Old Mar 27, 2016 | 07:05 PM
Mike02z's Avatar
Mike02z
When I had an iPhone I had the same problem in multiple cars. I don't think it has anything to do with GM. Since switching to Android phones, I never had a problem. I used BT over most of my first 5k miles and never had an issue.
Good luck but I don't think GM can fix this.
Old Mar 27, 2016 | 07:32 PM
Dano36's Avatar
Dano36
I thought 9.3 had cured the switching problem with my iPhone 6. Yesterday while driving and having the phone connected by BT, the car switched from my iPod which was plugged in and started playing music off my phone. Every time this happens it then fails to recognize my iPod until I unplug and plug it in again. Very frustrating.
Old Mar 30, 2016 | 09:14 AM
Richard Ames
Took The Corvette in for the A8 update and they gave me a 2015 Chevrolet Equinox SUV and my Iphone Blue Tooth works as intended with it. Different software.
There is a service bulletin 16-NA-042 I have not read it has anybody else?
