Splash Guards
Old Apr 1, 2016 | 08:29 AM
Corgidog1's Avatar
Corgidog1
Bought mine for the looks, use them for the protection. As others have said-should be std. equip.
Old Apr 1, 2016 | 08:44 AM
solarstingray's Avatar
solarstingray
why these dont come on from the factory is beyond me, on a 55k plus car,
Old Apr 1, 2016 | 10:58 AM
Randy G.'s Avatar
Randy G.
They gotta draw the line somewhere.
Old Apr 1, 2016 | 12:06 PM
iclick's Avatar
iclick
Why would they include them when they can sell you the stock set as part of the base price of the car plus the aftermarket units for another $100?
Old Apr 1, 2016 | 12:12 PM
PegasusCapital's Avatar
PegasusCapital
CF Senior Member
Originally Posted by Red-C6 of Jax
Worth the 120 bucks, should be a "standard" factory item.
Old Apr 2, 2016 | 12:57 AM
Iconic's Avatar
Iconic
Miller Time Wisconsin 🍺
2021 C7 of the Year - Modified Finalist
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13 thru '22
I too have the body colored splash guards from RPI. It takes less than 10 minutes to install a set of 4.
Front
Rear
Old Apr 4, 2016 | 01:14 AM
nmvettec7's Avatar
nmvettec7
OEM Splash Guards DIY paint to match Torch Red.
Old Apr 6, 2016 | 07:58 PM
jaki30's Avatar
jaki30
Did you use any primer for the rubber/plastic splash guards?
Something like the Fusion for Plastic ?
Old Apr 6, 2016 | 08:29 PM
nmvettec7's Avatar
nmvettec7
Originally Posted by [B
jaki30[/B];1591941985]Did you use any primer for the rubber/plastic splash guards?
jaki30:
The ABS Plastic Splash Guards were thoroughly cleaned, scrubbed with a solution of Simple Green, and then wiped down with a 70/30 mix of Isopropyl Alcohol to water. Then sprayed with an Adhesion Promoter (2 coats) then 2-3 coats of the body color match.
The key to the DIY project is patience when painting and making sure the coats are very dry before each coat, and making 100% sure the surface is properly cleaned for the acceptance of the Adhesion Promoter and then the body color paint.
The end result is a perfect flawless match. Both the Adhesion Promotor and matching body color paint are aerosol spray cans.
You can either buy one of 2 brands......Duplicolor or Automotive TouchUp. The Duplicolor paint can be found with an exact body color match at any AutoZone store and is much lower in price than the AutomotiveTouchUp brand.
Duplicolor also offers an Adhesion Promoter product
Hope this information helps.
Richard in New Mexico
Old Apr 6, 2016 | 08:32 PM
Fcal's Avatar
Fcal
Just ordered a set of OEM Race Yellow from RPI. Just have to wait a month.
Old Apr 6, 2016 | 08:38 PM
Strake's Avatar
Strake
2020 C8 of the Year Finalist - Unmodified
Besides the Splash Guards installed, we also added C7 Side Skirts (and front splitter).
Another thing to consider, and not too expensive is putting on Cleartastic Plus Protective Film. They are a forum sponsor and Ed was great to work with. They have several kits and I put on most of them..... These kits are for DIY installation.
Behind the Front and Rear Wheel kit, Rocker panel / Lower Door Protection kit, and I also put on the Mirror kit.
These REALLY help to protect the paint from stones, sand, etc kicking up.
Check them out.....
Old Apr 6, 2016 | 08:45 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
It's a nightmare on the Z06.
I ordered stage 1 knowing I would install the shirts, and splash guards because it was cheaper doing the aftermarket parts. The Z06 without anything is a gravel punching bag. The splash guards, and skirts eliminated most of the gravel hitting the doors, and rear fenders, but it was hitting the floor panels making that "cosmic" sound. All was fixed with two cans of undercoating.
