A/C button has no effect?
Old Apr 12, 2016 | 11:49 AM
jerrysmith2048's Avatar
jerrysmith2048
Default A/C button has no effect?
Hi all.. Wondering if anyone has ever seen this...
I've noticed on my 2014 if I'm driving and press the A/C button to turn off the A/C compressor and just want fresh air from outside, it seems to have no effect. The A/C compressor stays on and it blows ice cold air regardless of the fact that I turn it off with the button and the display screen even says "A/C OFF'.
Anybody ever heard of this? Sounds like a programming issue to me. Maybe I need a software update to fix this?
Old Apr 12, 2016 | 12:01 PM
Hopper12's Avatar
Hopper12
Hey Jerry, this is just a guess at this point (I'll check later this afternoon when I 'have' to wash my C7) - what 'mode' do you have the HVAC settings on? I believe if you have it in any of the defrost modes (such as the 'defrost/foot' mode) the a/c compressor will not be allowed to shut off . This is to help remove moisture for defrost purposes. If I'm wrong or that's not the issue, sorry about that.
Old Apr 12, 2016 | 02:48 PM
fdxpilot's Avatar
fdxpilot
Also, if you have the temperature **** dialed all the way to full cold, the AC will stay on unless outside temp is less than low 30s F.
Old Apr 12, 2016 | 03:21 PM
jerrysmith2048
Interesting... Then I wonder what is the point of having the A/C off button?
I've never owned a car that behaves like this. Including my C6.
Old Apr 12, 2016 | 03:23 PM
jerrysmith2048
No defrost. Just air from the main vents. Thanks for the input though, appreciate it...
Old Apr 12, 2016 | 04:02 PM
raylo's Avatar
raylo
Same as my Toyota Tacoma. If you dial the temp all the way down it turns on the A/C. It is just a simple shortcut to save you a button press by assuming if you go full cold you want A/C. Up one click on the temp then press the A/C button off. I haven't tried or seen that yet on my Vette but that is how it works on some other vehicles. I find it to be a little annoying.
To A/C button has no effect?
