Here's my solution to the cargo net situation. I did get the factory net with my 3LT interior but found it too small. So, I got the 3 compartment one off Ebay for about 12 bucks, I think. I mounted it in the rear and find its useful when shopping or carrying stuff around.
I moved the factory net up front, hooking it into the shade clips. Its handy to get to while sitting in the car and holds things you want or need up there.
This works for me.
What a great functional set-up. Good idea moving the cargo net to the front because mounting it in the back completely blocks the rear speaker when storing anything in it.
As previously mentioned, check the cubby hole in the trunk, as it is likely in there if you have a 2LT or 3LT. If not, it isn't much of a loss, as it isn't a very effective net--better than nothing but not much. I bought the one mentioned by Indy-hp and Frodo and it is much better.
