Shift boot install
Old May 11, 2016 | 01:28 PM
socaljet's Avatar
socaljet
Default Shift boot install
I AM THE HAPPY OWNER OF A D SHAPED STEERING WHEEL FROM VETTE CANDY AND WAS SUCCESSFUL IN GETING IT INSTALLED WITH JUST A FEW EXTRA APPLICATIONS OF THE PULLER.
I ALSO GOT A COUPLE SHIFT BOOTS AND AM RELUCTANT TO START PRYING IN FEAR OF BREAKING ALL KINDS OF PLASTIC CRAP. DOES ANYONE HAVE ANY INSTRUCTIONS TO SHARE?
Old May 11, 2016 | 01:31 PM
xp800's Avatar
xp800
Manual or auto?
I swapped my A8 shift boot to the suede. I can help with tips there.
Old May 11, 2016 | 01:52 PM
socaljet's Avatar
socaljet
Originally Posted by xp800
Manual or auto?
Please do. John
Old May 11, 2016 | 02:21 PM
The_Gretz's Avatar
The_Gretz
On a related note, I'd like the Comp Seats with the sueded inserts, but I don't want the suede wheel or shifter/boot. How hard is it to change these items back to standard leather? Seems like the hardest part of the steering wheel change is the one bolt that requires an impact wrench...?
Old May 11, 2016 | 02:27 PM
xp800's Avatar
xp800
Much easier to swap out your suede wheel and boot rather than swap in suede seat covers!!!
But having gone from leather wheel/boot to suede...I love it! The wheel feels so much more comfy. But YMMV.
Old May 11, 2016 | 02:50 PM
xp800's Avatar
xp800
Ok. So for the A8 boot...
  1. Set emergency brake
  2. Put the car in neutral: hold start button for ~7 seconds w/o foot on brake to get in "run/service" mode (dash lights and chimes), then press brake and shift to neutral
  3. You need to pry the whole black trim ring around the boot out (including the PRNDM ring). I did NOT use trim tools like the service instructions call for. I simply pressed my fingers into the boot and got them under the trim ring and lifted up. I had luck at the rear edge. It popped free. Be careful as there's a wire connector in this ring under the PRNDM area. There's enough slack to work with, just don't yank so hard that it pull the wire out.
  4. Once the trim ring is free, squeeze the shifter button and pull up REALLY hard with a bit of twist. The **** will release abruptly.
  5. Now that the boot and trim ring is free, you can work at getting the boot ring unsnapped from the trim ring. This is the part that took me the longest. Eventually using my trim tools I got it, but it took me ~20 minutes of fiddling around since I didn't want to be too rough.
  6. Snap the new boot into the trim ring (easy) and reverse the removal steps (also much easier).
Old May 11, 2016 | 03:10 PM
socaljet's Avatar
socaljet
Thanks. It's more involved than I imagined with the procedure involving the shift selector. :cheer
Old May 11, 2016 | 03:15 PM
xp800's Avatar
xp800
There may be a way to get the boot ring unsnapped from the shifter trim ring with leaving the trim ring installed. I would say trying that seems riskier than the way I did it.
But as I said, getting the whole boot/trim ring out of and back into the car was easy. Probably less than 2 minutes. It was me pussyfooting around getting the boot ring unsnapped that took the time. If I were doing it again, I'm sure it would take me less than 5 minutes end to end now that I know.
Old May 12, 2016 | 12:26 PM
socaljet's Avatar
socaljet
Most involved tasks are that way and I suppose that is what makes and "expert". Thanks again.
Old Mar 24, 2018 | 02:54 PM
rpm044's Avatar
rpm044
Cruising
C7 of Year Finalist (stock) 2019
Default C7 Console removal
I just installed an MGW short throw shifter. Their video on the C7 console removal is good. Read the warning about removing the first side trim piece from the back first instead of the from the front as in the video.
https://www.mgwshifters.com/shifters/corvettes/88
The stock shift boot was actually held up with a staple. Now I am trying to figure out if I can staple it up again.
Old Mar 24, 2018 | 04:42 PM
VictorBarron's Avatar
VictorBarron
Some have zipped tied them.
To Shift boot install
