A8 vs A10?
Goes up hills the others won't!
If they are all overdrive gears then I don't want or need it.
If the gears are between 3rd 4th,5th and 6th and tuned correctly then I think it would be a better driving car.
the A6 in my C6 was a new experience for me considering 6 gears was a lot at the time.I was also wondering what the big deal was going with even more gears when the A8 was introduced.
But now I like that even more than the A6.
The A6 would cruise between 4th and 5th on the back roads where as the A8 runs between 6th and 7th gear.
But there's a big difference when accelerating from a stop with the A8 as it goes up through the lower 4 gears.
The A8 zips quickly through the 1st 4 or 5 gears and gets you going pretty fast before you know it with only "light" throttle.
Getting further into the throttle from a stop and you have to watch where you're going
I like it and understand it more having one now.
How many gears are too much?
I don't know, I'm happy with the A8.
But as you mention, if the gears are setup correctly I think the 10 speed will be another nice Trans.
Just my 2 cents
People are complaining about it without driving it. The video of the ZL1 A10 track test sure doesn't disappoint the driver or passenger. I'm going to be optimistic about it and believe that Ford and GM can pull it off and it will work well. It is necessary for upcoming CAFE standards. Maybe GM can fit it in the C7 and get past the GG tax on the Z06 auto.
https://www.youtube.com/watch?v=zwTuJ-FAi8U
