A8 vs A10?
Old May 21, 2016 | 01:46 PM
Gonzo's Avatar
Gonzo
Default A8 vs A10?
Why is GM going to an A10?......Is it going to be significantly better ?.....or very similar to t he A8?
Old May 21, 2016 | 02:21 PM
L8ter's Avatar
L8ter
I think eight is two too many, but I'm not an engineer I just drive it.
Old May 21, 2016 | 02:31 PM
kp's Avatar
kp
I have no idea why a 6.2 liter, direct injected, high compression V8 with a pretty flat torque curve even needs an 8 speed torque converter auto.
Its not like the old BMW S65 V8 with the 8500rpm red line that didnt make 300ft lbs of torque anywhere or a little 2.0 4 cyl, that could use a 10 speed. LT1 has had 300 ft lbs of torque at 1000rpm
Only reason for a 10 speed is GM is just getting ready for smaller displacement engines and the EPA.
Old May 21, 2016 | 02:36 PM
Bettermost's Avatar
Bettermost
It has to be better than the A8, nothing could be worse at this point.
Old May 21, 2016 | 02:40 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
Huh, looky there, Black&White is back with a new username.
GM has said the A10 is too big to fit in the C7 so it's a moot point from that perspective.
Old May 21, 2016 | 02:43 PM
Z06 1of38's Avatar
Z06 1of38
Yep
Old May 21, 2016 | 03:02 PM
NinjamanZ51's Avatar
NinjamanZ51
2017 C7 of Year Finalist
I'm happy the A10 will not work with the C7, even with adaptation. That said, I'm glad this thread is moot.
Old May 21, 2016 | 03:33 PM
WelderGuy's Avatar
WelderGuy
Having 300 ft-lbs of torque at 1000rpm at WOT is meaningless 99% of the time. That said, it's hard to imagine how the most efficient power range can be so narrow that you need eight or ten speeds to get the best fuel mileage.
Old May 21, 2016 | 05:49 PM
USe-car's Avatar
USe-car
Boy, do I ever agree with you. Six is just right. The gearbox isn't always trying to shift into another gear.
Old May 21, 2016 | 07:24 PM
L8ter's Avatar
L8ter
In the good old days of 3 speed automatics, 1st would get you to 60, 2nd to 110, by 3rd, you were just seeing how fast the car would go...
Yep, I should be able to get my license suspended for the rest of my life with a 10 speed.
The heck with teaming up with Ford on the 10 speed.
I think GM should just work out the A8 issues to the point it's bullit proof, and tell the rest of the world to go pound sand!
Old May 21, 2016 | 08:05 PM
NiteriderFRC's Avatar
NiteriderFRC
Ahem...the new GM 10 speed seems to be the transmission they described the 8spd to be but is clearly not
Old May 21, 2016 | 08:26 PM
69L79's Avatar
69L79
From: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
With all of the A8 problems being reported on this Forum why would anyone have any confidence in an A10 from GM in a Vette? I drive manuals. But, I don't remember hearing about this many problems in the "outmoded" A6.
Old May 22, 2016 | 12:11 AM
Jay_Davis's Avatar
Jay_Davis
Because the A10 was designed by Ford???
Old May 22, 2016 | 12:31 AM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
I thought the the A10 wouldn't fit in the C7.
Old May 22, 2016 | 08:07 AM
Always Red Dave's Avatar
Always Red Dave
2014 C7 A6.
Old May 22, 2016 | 08:08 AM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Personally I am holding out for the A20. Heck I may even wait for the A30. If 10 is good more must be way more betterer.
Old May 22, 2016 | 09:21 AM
LIStingray's Avatar
LIStingray
I suspect after 10 speeds, the next step will be a CVT that can handle 700 hp.
All of this is courtesy of the EPA and its 54 mpg requirement.
Nothing gets better EPA fuel economy than a computer programmed CVT to maximize mileage in the EPA test cycle.
To A8 vs A10?
Old May 22, 2016 | 09:41 AM
427bob's Avatar
427bob
So those Camaro engineers are stupid for putting a 10-speed in the 2017 ZL1 Camaro?
Have you even listened to the video of that car on track? If that doesn't get you blood pumping, buy a Prius. I mean, listen to the car shifting. It sounds like the Corvette race car on track.
Old May 22, 2016 | 09:43 AM
rcooper's Avatar
rcooper
St. Jude Donor '15
Car trannys are getting like bicycle gears, single speed cruiser for paper route 50 years ago, 3 speed lighter weight, 10 sp "English" then the 15 speed ultra light weight, I now have a 16 sp with a "Bio crank" that helps to deliver more torque while peddling.
It is my weekend cruiser, 15 years old and less than 30,000 miles on it.
Old May 22, 2016 | 09:53 AM
1SG_Ret's Avatar
1SG_Ret
Seems the trend for more gears is to improve fuel economy and meet EPA standards. If the A10 does make it to the Corvette, I'm sure it will be fine as long as it's not adaptive.
The learning feature appears to be the root of the A8 issues. Going from aggressive driving (which the car begs you to do), to stop and go, seems to cause this problem to occur. Problem also seems arise if at slow speeds if you do quick brake and accelerator moves.
I have come to accept this behavior as normal In much the same way I accept the way the car responds when doing a tight turn as slow speeds and get the front end jerkiness (due to the tires). Nature of the beast
I've noticed that if I drive my car like a Toyota Corolla, it shifts fine all the time. If I do some aggressive accelerations and immediately return to Toyota Corolla driving I will get the occasional "lurch, "buck" or hard downshift.
