HELP removing visor warning label!!
Old Jun 24, 2016 | 04:39 PM
AirStingray's Avatar
AirStingray
Default HELP removing visor warning label!!
I'm really struggling removing 1 of the warning labels on the driver side visor.
I have the suede and it looks MUCH cleaner without the label.
The one on the passenger side came off so easily, with no heat gun or anything needed. Just peeled right off with a little work.
The driver side visor however, has been a PITA to remove and I STILL haven't been able to remove it!! Also it has slightly damaged the upper part (kinda hard to tell by the pictures) but it is almost impossible to get this removed..
Any help or advice would be much much much appreciated, as I think I have made it worse than just leaving the ugly sticker there.
Old Jun 24, 2016 | 04:53 PM
sTz's Avatar
sTz
I'd recommend 3M Adhasive Removal. You can spray it on a rag and dab it on label. "Generally" it will not cause discoloration, but I would first try it on a less noticeable area. It's available a most box stores and automotive centers, i.e., Autozone, Advance Auto, Pep Boys, etc.
Old Jun 24, 2016 | 04:54 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Hmm, I think you're probably screwed as far as salvaging it to looking like the other one. The visors aren't hard to remove, I'd probably remove it, then try heat and persistence in getting it off. You could try some goo gone, I think at this point it's not going to hurt it any worse. I think the covering will probably sag from being worked so much though.
Here's the part without homelink even though it's pictured (I think). You should contact them before you buy a replacement if you do. Otherwise, it stays flipped up most of the time anyway, ymmv if that bothers you or not leaving it. You could always cover it with another sticker, there are a few companies that sell corvette themed visor stickers.
http://www.cultragfactoryparts.com/c...&position=left
Old Jun 24, 2016 | 04:57 PM
E.T.D. Corvettes's Avatar
E.T.D. Corvettes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
Have you read through this thread?
https://www.corvetteforum.com/forums...ce-needed.html
Old Jun 24, 2016 | 08:41 PM
nmvettec7's Avatar
nmvettec7
https://www.corvetteforum.com/forums...-needed-6.html
Post #106 for a visual and easy fix.
Old Jun 24, 2016 | 09:38 PM
lancekl's Avatar
lancekl
Any help or advice would be much much much appreciated, as I think I have made it worse than just leaving the ugly sticker there.[/QUOTE]
If you can't get it off , take it to an automobile upholstery shop and they can recover the side with the sticker. I had that done on mine.
Old Jun 24, 2016 | 09:45 PM
springer-'s Avatar
springer-
Removes left over glue and softens the glue holding the label on. I have used it for years on all types of adhesives. Most recently used to remove my visor stickers.
Old Jun 25, 2016 | 08:35 AM
Beezvette's Avatar
Beezvette
My solution to the label problem was to stop fixating on it, leave them alone and do nothing. Worked out great and took no effort. :-) but it looks like you are committed at this point.
Old Jun 25, 2016 | 09:14 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Hmm, suggest considering what you have done your best choice is to do what many have posted, cover the area with self adhesive vinyl!
I thought some folks were selling precut pieces. To cover a C7 car model roof I purchased carbon fiber look vinyl. Have seen posts where folks used that, it comes in 8 1/2 X 11 sheets.
Old Jun 25, 2016 | 03:02 PM
AirStingray
Well... The driver side suede covering is completely off the visor now lol... I think I'm going to just order another one and leave the warning label on this time..
Old Jun 25, 2016 | 06:36 PM
dval's Avatar
dval
I ordered two cloth black stickers from sunvisor solutions .looks good not perfect. Thay are $15 shipped
Old Jun 25, 2016 | 06:50 PM
bbcb's Avatar
bbcb
sorry cant help ya .... glad I left mine alone ... like fights ..don't start unless ya can finish ..
Old Jun 25, 2016 | 08:56 PM
B&BVettes's Avatar
B&BVettes
It's illegal to remove these labels! Similar to mattresses and furniture cushions! Watch out for the label police!🚨🚔
Old Jun 25, 2016 | 09:45 PM
Mike Mercury's Avatar
Mike Mercury
FYI
the warning that it is unlawful to remove the tags from a mattress or pillow is not for the end purchaser. It is for new pillow and mattress sellers only. It's only against the law to remove the tag prior to the sale and delivery of a pillow or mattress to the final consumer.
Old Jun 25, 2016 | 09:53 PM
owc6's Avatar
owc6
Anyway, back to the issue at hand; my passenger side came off easily in two or three pieces, but my driver's side shredded into hundreds.
I just used tweezers and a lot of time and patience. They came off eventually, and did not require any goo gone or equivalent.
Old Jun 26, 2016 | 07:39 AM
KuzVette's Avatar
KuzVette
I got mind off 1-2-3 with a heat gun and then got rid of the glue with Goo Gone!
Old Jun 26, 2016 | 08:32 AM
fltsfshr's Avatar
fltsfshr
Let me help you. Sit in the drivers seat and put a towel on your lap. On the highest edge use a q tip to put some goo gone on it. Let it sit for just a few seconds and then slowly peel just a little bit along the edge where the goo gone has penetrated. Don't tear it off just run your q tip along the inside of the edge you just made. More will peel back. Keep repeating till it's all off and wipe the area with a clean towel and Goo Gone (Goof off works too). Mine are suede and it worked great.
fltsfshr
To HELP removing visor warning label!!
Old Jun 26, 2016 | 08:52 AM
L8ter's Avatar
L8ter
When your new one comes in, try heating it up with a heat gun or blow dryer. The glue may not have set too well, and it may come off clean. The key words here are may.
Old Jun 26, 2016 | 07:46 PM
AirStingray
Thanks for all the help my friends! I got the label off but my visor is now the ugliest thing ever to look at since the suede has been removed along with the label.... Ugh.. Going to place a order on a new visor from the dealer hopefully tomorrow.
Old Jun 26, 2016 | 08:47 PM
lancekl's Avatar
lancekl
Just take it to an auto upholstery shop and have them cover the side with the sticker. May be cheaper than a new one.
