Black soot on outer pipes....
Old Jul 21, 2016 | 06:36 PM
coupeguyz51's Avatar
coupeguyz51
Default Black soot on outer pipes....
I have a 2014 Z51 and have turned the "sound management" to "off" for that sweet burbling sound....when I have not had time to do a thorough detail job, I have noticed black soot on the two outer pipes...the inner ones look shiny....
I was thinking perhaps that turning the sound management off just bypassed the mufflers, but it doesn't sound loud enough to be just straight pipes as on some other beasts I have owned...
Anyone have an explanation for the soot?
Old Jul 21, 2016 | 06:38 PM
UKnowWho18's Avatar
UKnowWho18
I have same issue with my Z06. Posted about it here on the forum and was informed it is completely normal.
Old Jul 21, 2016 | 06:45 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
normal, with the sound mgmt turned to the "off" position, 80% of the time the exhaust is heading out the outer pipes. I pulled fuse 42 and have the exact same thing, routine cleaning and polishing will relieve any permanent soot build up.
Old Jul 21, 2016 | 06:55 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
The richer starting gas mixture comes straight out out those lower restriction pipes versus going thru baffles in the muffler in the center pipes. That happens when you start regardless of the mode set. Until the exhaust gets hot, the water, which is a significant product of combustion, is liquid and causes the carbon to drip out.
Old Jul 21, 2016 | 07:06 PM
dvilin's Avatar
dvilin
Old Jul 21, 2016 | 08:13 PM
sTz's Avatar
sTz
Normal w/the NPP.
Old Jul 22, 2016 | 01:01 AM
Foosh's Avatar
Foosh
Originally Posted by JerryU
The richer starting gas mixture comes starlight out those lower restriction pipes versus going thru baffles in the muffler in the center pipes. That happens when you start regardless of the mode set. Until the exhaust gets hot, the water, which is a significant product of combustion, is liquid and causes the carbon to drip out.
Yes, this.
If you don't let it build up over time, just a quick spray w/ detailer and a rag keeps them shiny. Even if you do let it build up, any metal polish very quickly takes care of the baked on soot.
Old Jul 22, 2016 | 01:53 AM
Z06 1of38's Avatar
Z06 1of38
#blacksootmatters
Old Jul 22, 2016 | 07:47 AM
Elite275's Avatar
Elite275
Run E85....problem solved...no soot and clean pipes always.
Old Jul 22, 2016 | 07:52 AM
MAKC7's Avatar
MAKC7
Wipe mine down after every drive with my wife's kitchen stainless wipes.
Old Jul 22, 2016 | 07:56 AM
DCortez's Avatar
DCortez
I'm going to clean mine .... one day
Old Jul 22, 2016 | 08:15 AM
RUSTYNKL's Avatar
RUSTYNKL
When I fill up at the gas station, I use one of their wipes, dip it in the cleaning solution and wipe the pipes off. 2 min.and done, then the people there start talking!
Old Jul 22, 2016 | 10:23 AM
JerryU's Avatar
JerryU
Yep, goes away completed when the engine fails!
Old Jul 22, 2016 | 05:39 PM
coupeguyz51
Originally Posted by Z06 1of38
#blacksootmatters
Old Jul 22, 2016 | 05:42 PM
coupeguyz51
This makes sense....question...are the two outer pipes going through the muffler with sound management "off" are does doing that completely bypass the mufflers?
Old Jul 22, 2016 | 07:36 PM
Frodo's Avatar
Frodo
The two inner pipes are the fully muffled pipes. They are always open. The two outer pipes are the NPP "loud" pipes. They eliminate a lot of muffler when they open, thus louder. They get smutty when the NPP is open, path of least resistance, and stay clean when they're closed. If you look inside the two outer pipes you can see the NPP valves, butterfly type valves, that open by computer command. Or by removing the fuse, or by changing the driving mode, or by a switch installed by the owner.
Old Jul 23, 2016 | 12:37 AM
owc6's Avatar
owc6
#blacksootmatters
To Black soot on outer pipes....
