Brake fluid protocol
Old Jul 31, 2016 | 09:31 PM
John6l6's Avatar
John6l6
Default Brake fluid protocol
This question is for the racers out there.
What is your protocol for checking brake fluid at the track events. I know many will bleed and use racing fluid but how do you monitor temps mid day to make sure the temp is not to high going into a session. I had a total brake failure in my second session from boiling the brake fluid on the first straight away. I do not want this to happen again. What can I do to monitor this in between sessions?
Old Aug 1, 2016 | 05:38 AM
spearfish25's Avatar
spearfish25
What fluid were you running? With a solid 40-90 minutes between most HPDE sessions, your brakes should be relatively cool by the next time on track. An early session failure like that sounds like you boiled them in the previous session and had air in the lines for the subsequent 'trouble' session.
Old Aug 1, 2016 | 06:21 AM
Iconic's Avatar
Iconic
Miller Time Wisconsin 🍺
2021 C7 of the Year - Modified Finalist
2018 C7 of Year Winner
2017 C7 of Year Finalist
St. Jude Donor '13 thru '22
Between two Vettes, a C6 GS and a C7 Z51, I have tracked Daytona, PBIR, Sebring, and Road America, I used Motul 600 in both and never had a single issue with boiling the fluid. These were all HPDEs where you run four 30 minute sessions per day. I did get a "service active handling" light once on the GS on day 3 at Road America due to the brake fluid reservoir being low from brake pad wear. A few ounces to top it off and the CEL went away
Also, it take 2 pints of new fluid to completely refill the whole system during bleed/flush.
Old Aug 1, 2016 | 09:33 AM
daleong's Avatar
daleong
Hi John,
What track were you at out of curiosity?
You might want to post this question in this thread in another forum section - lots of braking experts and vendors there.
https://www.corvetteforum.com/forums...post1592716398
Old Aug 1, 2016 | 11:41 AM
John6l6's Avatar
John6l6
Most Likely. I was running stock but I switched to Motul 660 but they still started to get mushy towards the end of just 1 session. This track (Eagle Canyon Raceway) was brutal on the car. I have had no problem with any other tracks but this one has a lot of 130mph - 20mph turns and I was really pushing the car with very late braking points.
I just would like to know what I can do to monitor temps between sessions as a precaution next time.
Old Aug 1, 2016 | 12:22 PM
08G8V8's Avatar
08G8V8
The DBA rotors have thermal paint on them that change colors at various temps. Will give you a quick indication you exceeded a certain temperature.
Old Aug 1, 2016 | 01:23 PM
John6l6's Avatar
John6l6
Is there a way to roughly calculate brake fluid temp based on brake caliper temperature?
Old Aug 2, 2016 | 10:40 AM
Captain Buddha's Avatar
Captain Buddha
Hey John, Brad here....
You might want to check this:
https://www.corvetteforum.com/forums...-splitter.html
For all of your track day/racing questions, this is a really good sub-forum:
https://www.corvetteforum.com/forums...roadracing-23/
Old Aug 2, 2016 | 10:52 AM
John6l6's Avatar
John6l6
lol thanks for the splitter thread...
Old Aug 2, 2016 | 11:01 AM
Captain Buddha
Don't forget the carpet fiber (and unobtanium inserts):
http://www.autozone.com/decals-and-g...mpid=PS:3:1:51
Old Aug 2, 2016 | 11:14 AM
John6l6's Avatar
John6l6
I like the idea of a disposable splitter but I am not putting $7.00 wood on 70k car. With or without a sticker. lol. I would want something more brittle and lighter. My luck, plywood would rip off my front bumper and then catch of fire.
To Brake fluid protocol
