SD Card
Old Aug 1, 2016 | 10:32 AM
aerobaticflyer's Avatar
aerobaticflyer
Default SD Card
Does the Vette come with a blank SD card? Just wondering before I do my museum delivery in case I need to bring one. Thx.
Old Aug 1, 2016 | 10:50 AM
Boiler_81's Avatar
Boiler_81
The car does not come with an SD card from GM. I understand the Museum has provided a small SD card as part of the delivery. I have no idea if they are still doing it. Maybe someone with a recent delivery will chime in. If not you can contact the museum for the current policy.
Personally, I would grab a larger one from Amazon and take it with me. Remember, anything larger than 32 Gb will require a third party application to format it to FAT32 under Windows.
Old Aug 1, 2016 | 11:24 AM
defaria's Avatar
defaria
You're spending like $50-70K on a car and you're expecting to also get a $50 sd card for free?!?
Old Aug 1, 2016 | 11:30 AM
Cur's Avatar
Cur
Just a note: A 256Gb card *does* work with the PDR system.
Old Aug 1, 2016 | 11:59 AM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
I don't think he was "expecting", just asking a simple and fair question.
Old Aug 1, 2016 | 12:19 PM
blue max's Avatar
blue max
We got one with the museum delivery. However, I bought a 32 gig before going to Ron Fellows
Old Aug 1, 2016 | 12:27 PM
Rat Racer's Avatar
Rat Racer
Just another note: A 512GB card also *does* work with the PDR system...
However, the PDR will only record in up to 99 minute blocks. So, if you want to record a drive longer than 99 minutes (like, say, the Twisted Sisters scenic drive in central Texas), you will need to stop and restart the PDR before the 99 minutes is up.
Hunter
Last edited by Rat Racer; Aug 1, 2016 at 12:31 PM. Reason: Add info about the PDR time limit
Old Aug 1, 2016 | 01:01 PM
aerobaticflyer
No expectation at all....I'm just trying to make sure I have a card for the ride home in case I play with the PDR.
Old Aug 1, 2016 | 01:02 PM
aerobaticflyer
Exactly TY.
Old Aug 1, 2016 | 01:27 PM
davepl's Avatar
davepl
Just in case you're curious, the 256G card gives me about 6000+ minutes (100 hours, I guess) of recording, which is plenty. So I presume the 512G would be 200 hours.
I still wish you could set it to come on every vehicle start (like in Valet mode).
Old Aug 1, 2016 | 06:17 PM
MildBill's Avatar
MildBill
Just a point of curiosity, but why would anyone need to record 4 days worth of video? It would be like in the old sitcoms where someone is showing a dinner guest hours worth of slides from their summer vacation.
The files are mp4, so I can remove the card and transfer the files to a PC. I have an old 8gb microSD that will give me 188 minutes of recording time. I can't envision needing to record DAYS worth of driving. Am I missing something?
Old Aug 1, 2016 | 08:22 PM
davepl's Avatar
davepl
I put the card in and use it every time I drive as a dash cam. I never have to worry about making room, deleting files, or maintaining it.
I wouldn't want to have to swap out and clean the card every 3 hours....
Old Aug 1, 2016 | 08:28 PM
PapaLeo67's Avatar
PapaLeo67
Old Aug 2, 2016 | 08:22 AM
Greg00Coupe's Avatar
Greg00Coupe
The 32K card I got at Best Buy for like $16........ 720 some minutes. I just wish the system had an option to always play and loop over the recordings.
Old Aug 2, 2016 | 08:30 AM
Cur's Avatar
Cur
As mentioned by others, I use the PDR as a dash cam every time I drive. If I'd have known 512Gb cards worked, I'd have gotten one of those
Old Aug 2, 2016 | 09:17 AM
defaria's Avatar
defaria
Some people are humor impaired...
Old Aug 4, 2016 | 06:36 AM
MildBill's Avatar
MildBill
More power to you multi gigabyte dudes! I'm never coming over to your houses to watch video of your cruises from Houston to El Paso though!!!
To SD Card
Old Aug 4, 2016 | 06:45 AM
Thunder22's Avatar
Thunder22
I think you mean 32GB not K
Old Aug 4, 2016 | 11:12 AM
Exhausted45's Avatar
Exhausted45
We got about 10 hours on a 32GB on a road trip to the Black Hills. Does anyone have a suggestion for an editing program? I'd like to eliminate some really boring video.
Thanks,
Old Aug 4, 2016 | 12:01 PM
iclick's Avatar
iclick
Thanks,
I use VideoRedo TVSuite v5, but at $95 it may be overkill for just editing 720p PDR files. The red section of the bar are the areas I cut out, green sections are included. Those four green sections are listed in the upper right and are merged together in sequence when saved to another (smaller) video file.
There are probably some freeware progs that would work fine for this purpose, but if so I'm not familiar with them.
